Cooking them with abundant solder and poor technique surely didn't help.
Now he knows he damaged his cells if he was once raving about Lifepo4's and now calling them junk
Yea.
There is one huge problem with that theory however.
I have no other LIFEPO4 batteries to compare them to. How do I know if that much SAG is a normal thing with LIFEPO4 cells. If I do not have a 12S factory made spot welded pack to compare mine to then we are guessing that the packs I soldered are severely damaged.
I posted a representative LiFe discharge graph that clearly demonstrates the typical LiFe charge and discharge "voltage lag".
They will still run at least four of my e bikes. They just will not go 30 mph at 12S - 43V. I still have not ran them at 54V - 15S.
That will happen soon. Just waiting on the active balancers which will keep any cell bank from going too low.
Not what they do!
Until then I am working on the LTOs. One way or the other I am blowing these junk gas bikes off the road. I do not like being passed by gas.
Speed is the enemy of range!
Thanks.
9"45 PM.
Yea.
I just went back to Wall-Mart again. Same trip. Basically the Currie is a super reliable street legal cargo bike. It is not currently set up to beat a well built 50cc gas powered mountain bike. For one thing the gas bike has gears for hills and top speed. I do not.
Also the problem with the batteries is NOT my soldering job and here is why.
Brand: K2
Model: LFP26650E
Capacity: 3800mah
Nominal Voltage: 3.2
Fully Charged Voltage: 3.65 (recommended), 4.1 (maximum)
Fully Discharged Voltage: 2.5 (recommended), 2.0 (maximum)
Continuous Discharge (A): 12
Pulse 30 Seconds Discharge (A): 28
Charge Current (A): 3.8
compare those specs. to these.
NOMINAL VOLTAGE: 3.2V
CAPACITY: 6000MAH
WATT HOURS: 19.2WH
FULLY CHARGED VOLTAGE: 3.65V
FULLY DISCHARGED VOLTAGE: 2.5V
MAX CONTINUOUS CHARGE: 6A (1C)
MAX CONTINUOUS DISCHARGE: 18A (3C)
MAX PULSE DISCHARGE (10 SECONDS): 60A (10C)
CELL WEIGHT: 141 GRAMS OR 4.97 OUNCES
I bought the wrong cells. The cells I bought are low capacity and lower discharge. That is why they SAG like they do. Once I move and get settled I will buy a bunch of the better higher grade cells and will go 18S - 6P.
Just because you suspect 1 Cause, does not eliminate another cause.
3.8 * 5 = 19 vs 6 * 6 = 36.
Yea. Also 26650 LIFE cells are rated for capacity a lot different than Lion or LiPo. They rate LIFE down to 2.5V which is only 30V @ 12S. way too low for most 36V controllers. Basically I am only running about 10 Ah compared to Lion. LIFE is 1/2 the capacity of Lion. If I build a 36 Ah - LIFE pack it will = 18Ah of Lion. It is the trade off for > 5,000 charge cycles.
30V is a standard 36V LVC.
I need at least 10 miles preferably 15 miles before I need to recharge. Otherwise I cant go from one town to the next. The LIFE packs I have now have a < 10 mile range before they will trip an LVC. It is why I am running the brush controller that has no LVC. That will not help me with my brushless motors however so will be building a larger LIFE pack with the better cells.
Running a controller with no LVC, to get more range, is a pretty sure way to destroy more cells!
Until then I will run what I have but will soon be running 15S - 5P which should get me an upgrade in performance over 12S - 5P. Maybe 3 or 4 extra miles also if I stay around 10 mph. It will have to do for now. Fortunately most of the places I go are < 5 miles and have places where I can recharge. Therefore I will get a lot of use from the inferior cells I have now.
Even at 15S the lower capacity and discharge cells might not beat the gas bike but will at least give it a better run for its money.
The LTOs however should smoke that gas bike.
Better get a trailer to haul around all that LTO!
The question I had for DA. remains unanswered. Since - the 24 - LTOs I own are only 18 Ah and way too expensive to order more the best bet for an electric motorcycle and the 28 kilowatt Sevcon controller is 12 of those power modules DA recommended.
I will require a 400 amp 96V - BMS.
Have you even tested the 13s "power modules"? Been setting for months!
Since I fall a little short from being a professional reputable e bike builder I was hoping someone more experienced could hook that up. If not DA. then someone with at least a Bachler's degree in electrical engineering who is not scared to death of high current and voltage applications.
Anyone with basic electrical awareness, and common sense, should be "qualified". As mentioned earlier I decline to try to idiotproof anyone's wet dream ... LC would prove too clever, and defeat my efforts!!
Thanks.
LC. out.
