latecurtis
I should be able to plug balance wires in before I even switch to charge posistion if switch has a center off posistion.
I have to recommend going this way!DrkAngel said:DrkAngel said:All your diagrams seem designed as 1p.
You are using as 2p!
You are trying to think way too complex.
Rig your packs as 2p 1st, then consider them as 1 pack for diagram and function purposes.
Use pos & neg power Y plus balance Y to turn 2 - 6s1p packs into a single 6s2p pack 1st and view it as such.
Do not hard wire your packs together!
Connectors are reliable and allow easier diagnosis, repair and replacement.
Less confusing?
Added dual connector with jumper wire to diagram and angled the Y wires
To switch from run to charge: KISS ©®
1. remove jumper connector
2. remove volt meter alarms
3. remove controller
.... 44.4V Battery .... 48V Controller ....
4. plug in power 2Y and balance Y from charger
(always leave Ys connected to charger )
.... 2x 22.2V Batteries .... 22.2V Charger ....
As simple and idiot proof as possible!
Unless unable to tell red from black ...
Possible with directionalized bullet connectors to further idiot proof! ... if deemed necessary?
Charger quick connect included.latecurtis said:http://www.ebay.com/itm/44V-48V-50-4V-4A-Lithium-ion-LiPo-Li-Po-Battery-Charger-12S-12x-3-6V-3-7V-Lion-/321188975380?pt=US_Rechargeable_Batteries&hash=item4ac85ad314#ht_7081wt_1051
I am not sure if the mega charger Dan sent is a 12s or not. I think a 6s. With a 12s charger i could hook the switch up myself with a little diagram from Drkangel. I would not need an electrical engineer. That was the first 12s charger that popped up. About what i paid for the sky charger. Wish i knew that then. I know that you guys are used to hooking and unhooking things and see no sense in na switch. But I bet if you had a switch and used it awhile you would never want to go back to plugging and unplugging every time.. Thanks. Latecurtis.
$86 for 4A 12s bulk charger isn't a bad price ...DrkAngel said:Well, with a bulk charger ... there is no need to "switch" anything.
Just an on/off switch when not using or controller will slowly bleed down the battery.
Plug in charger to charger port
Charge
Just need the volt meter alarms to monitor and confirm bank voltages being proper-safe. - Alternative to balance charging every cycle.
