DrkAngel
1 GW
No rear brakes.latecurtis said:The diagram I just posted has to be opened up but is probably the last of that type of fork motor mount. I don't see any way of improving it any further. I admit it does stick out like a sore thumb however it will not interfere with the front brakes. Also the rear mount DA posted looks like it would interfere with the rear brakes.
Rear brakes are minimally effective, at best.
Use fixed sprocket, release throttle and motor will act as brakes. Most effective for deceleration from high speeds and for long downhill runs ... will never overheat or wear out.
(Spoke mounted sprocket ... as used by most gas motor add-ons)
With maximum deceleration rear brakes contribute nearly nothing!
Near the point of tipping, ~ 100% of weight and stopping power is on the front tire
Most notably with the 20"er ...
With the high center of gravity and the short wheelbase ...
Even the best rear brakes will be nearly useless!
Of course, ... good front brakes are liable to put you on your nose!
