playvltk03 said:
I agree with you on this, however with me it look like half baked product. Your valuable time and material has helped make this product great but I don't know why the manufacturer wouldn't do this in the first place or at least have some decent firmware rather than expect people to flash and do their work. I bought a motor, I expected it to work as its specification, this 500w motor operated like my 350w rear hub and it's not acceptable, in which later I found out, there are 48v version, 48v overlock version, 52v version, 52v overlock version, tsdz2b version and so on, I also found out not all of TSDZ2 has throttle enable, that means some work with throttle, some doesn't and you either have to replace the controllers and or change the display. This gives no different than having a hub drive and just change the controllers (in fact this might be the easier way).
Flashing and change the controller seems like a great way to increase this product but It doesn't make much sense for me, for 2 reasons, where I'm at (Western Canada), it's outrageous shipping import and duty to buy all the items required (cable, display) for the flashing, 2nd reason is that even if i'm willing to spend money for 1st, i prob have to wait like 2-3 weeks and when the winter came, it is going to be for next year riding.
I agree with you it look promising, but until they standardlized their product at least and make the setting works, I would not touch it. Some experiment was fun, this wasn't, a good product required firmware to make it better, this make me felt like the firmware make a bad product become bearable.
Again, no pun intended, i think you and other worked on the open firmware has did a great job, the manufacturer should have bought your time and the software code making their product better. As far as they didn't do that or even not having the functionality that you guys spend time and efforts on, I'll stay away from this.
Hi, just to be clear I am not working on the open firmware. Casainho and some others are working on that, I am not using that nor do I endorse it at the moment. I have not even tried it so I really have no opinion on it other than I would wait until it is tested and deemed safe. I too do not wish to use it based on cutting cables, rewiring, using an aftermarket display etc. I have not done much, if anything, on this motor and I am just a user and not modifying it in any way except for battery voltage. I only post from my experiences and try to help others when possible.
I completely agree, the manufacturer has dropped the ball on this motor. Furthermore the motor is defective and the gears do not mesh properly thus making premature failure of the nylon drive gear almost commonplace. The display functioning does not work correctly either, and they can't even get their quality control to ensure the motors are flashed for the correct voltage before shipping.
I think the Lingbei might be a very good motor, but you are 100% correct that it is not completed yet nor tested. It only has potential to be good. Only time will tell if it lives up to it's potential.
There is a way to flash the motor with the original firmware. The user Eyebyesickle is working on program and memory files to flash so it will work with the original equipment. If you download the 750w 48w firmware files and flash it should at least have more power.
I was not endorsing that you buy this motor. I was only trying to help you because I assumed you owned it and were keeping it so I tried to give you some options. If you have not bought it you are correct that Bafang is more reliable and a more polished product, and perhaps the Lingbei will be good if a torque sensor is desired but only after the finished product is released and tested thoroughly.
I hope this clarifies my position
You do not want to read back through 130 pages but I have been vocal about this motor being defective and the manufacturer not doing anything to correct the issues.
