EndlessCadence
- Joined
- Aug 22, 2018
- Messages
- 217
I've just tested it again and I had no issues downloading from the ST website, but you have to register first before downloading. Btw, I'm using ST Visual Programmer (STVP) not STlink.cascarabias said:Thank you very much for your answer, but it is impossible to download STlink from the web, I downloaded it from "www.eco-ebike.com/blogs/eco-cycles-instructionals/tsdz2programmingfromscratch", I have run the program but it gives me the error "Error: Can not communicate with the tool.
Wrong tool selection or check tool power supply or check that a previous session is closed.
Error: <PROGRAM MEMORY programming failed.
Error: <Operation aborted "
I checked the connections and I think they are correct. some idea for a solution.
Best regards
Regarding the communication issues, did you wire the power/VCC to the ST-LINK/V2 programmer as well or are you using another power source? The device (in the motor controller or display) needs power otherwise you can't communicate with it.
