KT-LCD3 is on the way, cables are here.
Following advice on the thread I ordered a HIGO B8 from e-bike-technologies.de
https://www.e-bike-technologies.de/index.php/en/connectors/higo/higo-main-connectors/higo-b8-detail
and a Bafang BBS 1T4 bus cable
https://www.amazon.com/gp/product/B07B7B7YJF/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Eyebyesickle proposed this pair, what I like about it is that it includes connectors for Bafang throttle and brake sensors and apparently those devices work. It has the a green 5-pin connector that I think will directly connect to the KT-LCD3.
It is the 8-pin connector on the Bafang cable that has to be changed. The Bafang cable 8-pin connector is male, same as the TSDZ2 motor cable. Cut off the male 8-pin connector, replace it with the female Higo B8, and I should be ready to go. Because I am not messing with the existing TSDZ2 cables I can go backwards if I want to.
I did not see a pin map of the Higo B8, so I made one
Can you guys point me to a post or something that shows the wire connection I need to make? I am hoping the Bafang cable is common enough so it is already mapped.
I will, after I make it, post an instructional about making a cable this way that to help others.
Thanks.
