valsam said:My friend ,my car only needs a 20$ oil change after 20.000km!
bluesoc said:valsam said:My friend ,my car only needs a 20$ oil change after 20.000km!
I would buy that car immediately if that's the only maintenance it requires!
I did own both that motors before changing to the mid drive motors with TSDZ2.dahu33 said:I've created the thread below a few days ago but I haven't got the traction I was expecting. If anyone own or previously owned both a TSDZ2 and a Q100 or Q128, I would love their opinion and feedback there.
TSDZ2 mid-drive vs Q100CST hub motor?
As I also told, in my experience, I do much more maintenance, but because I take much more out of them.valsam said:Dear casainho you are basically telling us that the TSDZ2 running OpenSource firmware is a better choice in every aspect(more efficiant,more torque,better for mtbikking,better for commuting, ect)compared to hub motors such as the Q100 or Q128 but with the only negative that it needs needs more maintainance
(and realy how much will it hurt our pocket for the broken down parts for this maintanece?) ,but what if someone does not want to void his warranty and has to keep his tsdz2 with stock firmware for 1-2 years, how does a stock TSDZ2 compare to the above hub motors?
I am asking because if most of the above advantages that the TSDZ2 running OpenSource firmware has are not present in the stock firmware that the tsdz2 comes with(or even if the stock TSDZ2 has still some but small advantages ) compared to the hub motor and you only get the more maintence part then that's another ball game my friend!
ezrider1199 said:Hi, I was trying to install an accessory front light (DIY) and seeing some strange stuff. When the LCD3 light is on, the accessory voltage is 2v however when LCD3 light is off the voltage is jumping around 6-9v. And when the LCD3 light is off, i plug in my light the voltage just drops to 0. Is this normal?? I'm pretty puzzled by this, especially since my light works fine via a bench power supply (tested 4-10v)...
The lights are dual LEDs that i had them wired in series at first and then in parallel. The series didnt work out because the first light was taking all the voltage i assume. But the parallel should work (tested via bench power supply). I hope i didnt mess anything up... rest of the bike works A+
I were very happy with hub motors!! I am sure you will also willvalsam said:From the little that i have learned reading posts here and elsewhare (dont forget i am a noob!)i understand that a hub motor has limitations ,can't go MTBiking,and are less efficient with lower torque but they are damn cheap and pretty reliable compared to the above mid drives,so i ordered 3 more naylon gears (15$ all 3) and some lithium grease for just in case and hope that i can achieve that 10-20.000km lifespan!
It is very hard to repair parts of the motor controller. There a specific circuit to limit the current for the lights, maybe it burned. I would buy another motor controller to replace.joselinh said:Hi, something happen to my DIY lights. They works fine a couple of days, and then turn off.Maybe overcurrent.
Dont know how to repair it. Any fuse inside, some reset? any idea? Dont want to put an external switch!
casainho said:It is very hard to repair parts of the motor controller. There a specific circuit to limit the current for the lights, maybe it burned. I would buy another motor controller to replace.joselinh said:Hi, something happen to my DIY lights. They works fine a couple of days, and then turn off.Maybe overcurrent.
I am just waiting to be a father again and then have a reason to justify buy a Bullitt cargo bike like yours and also put TSDZ2 in it!!mscoot said:Open source firmware: Where do I begin?
I've been happily riding around with my stock 250W tsdz2 since 2016 and I've also been following this forum on and off out of curiosity for the open source firmware project. There's a lot of information in this thread to sort out for me, so I was hoping someone here could help me sum it all up.
Recently my xh-18 display stopped working properly. Everything looked normal, but I was unable top change power levels and the display seemed to choose an arbitrary max speed of ca 23 km/h. This was annoying so for the time beeing I have reverted to the old vlcd-5, but I'd rather like to try out the open source firmware and a new display.
For training and workouts I ride my road bike, but for my daily transport around town the Bullitt cargobike with the tsdz2 is what I use all year round. Because of mye road bike fascination, I tend to ride with a high cadence (80-100 rpm) and my tsdz2 isn't particularily good in that area. It seems the new firmware solves this issue.
Every now and then I also carry heavy loads up towards 100 kgs. I'm not expecting to be able to ride that sort of weight up a hill at any kind of speed, but the way the power is delivered from the tsdz2 (max somewhere around 80 rpm) means it doesn't match up with my own max power at around 100-105 rpm. The regular weight of the bike with the normal daily load is about 50-60 kgs plus my own 80 kgs. The low cadence on the motor also means I'm not as able to carry the speed over rolling hills the way I would on my road bike. I hope the open source firmware can help sort this out in a better way.
In stock form, the 250w motor is a little weak. I'm fine with that actually, but the annoying thing is the way max power drops off as the battery level goes down past 60%. If I understand this correctly, the open source firmware fixes this issue? As it is now I usually regard the battery as empty as soon as I'm below 50% charge which gives my approx 500 wh battery a range of a measly 30 km. Of course, the battery isn't empty, but power drops off too much for the motor to be of much use. This is worse during winter than in the summer, of course.
I see quite a few places recommending adding the temp sensor. Since my bike is heavy and I like to ride as fast as possible I suppose adding one would be smart. However, do I need a special controller for this? I only have the stock 36v controller that came with the motor in 2016.
Now, trying to wrap my head around the installation procedure, I think I have come to realize that I'd rather pay for a new controller and display with everything installed. Would this be a sensible way of doing this or are there other good reasons to install and flash it myself?
I can buy an 850c display locally (I like supporting my local (e)bike shop). Perhaps even some of the cables and wires can be sourced there if needed.
I don't have a windows-pc, but my flat is full of apple-computers. Is this a problem? Can I perform the installation and firmware flashing with an apple computer? Years ago I used a gimbal for an RC-drone that need firmware updates through a windows program I ran through some sort of emulator on the Mac. Does any one here know if this sort of thing still works?
I'm a little afraid of bricking the whole motor during this procedure in case something goes wrong. Will there be any way of resetting or reverting to the old firmware at a later stage?
Thanks for any help or information.
famichiki said:I have a 48V motor and just bought a 52V battery and intend to use the OpenSource firmware, but first I want to try it out with the factory firmware for comparison.
I understand that to use a fully charged 52V battery on my 48V motor I need to make some changes to the factory firmware.
The Eco Cycles website has a guide to modifying the factory firmware, but there's a note saying it's no longer recommended because "New/Alternate TSDZ2 Firmware versions can restrict changes from taking effect". Instead they recommend flashing one of their complete profiles.
https://www.eco-ebike.com/blogs/eco-cycles-instructionals/tsdz2programmingfromscratch
Does anyone know exactly what the problem is with the old way now? Would it be just that the memory locations could be different?
Also they seem to only have one version of the 52V factory firmware for download, but should there be different versions for throttle/non-throttle?
Genesis Andy said:I bought my TSDZ2 kit preprogrammed with open firmware V 18.2 I believe. What improvements is there over my version and the 20. ?
Im perfectly happy with the way the motor works and the settings I've adjusted. The bike is running a 52V battery.
If in the future I have a motor controller failure will I be able to install 18.2 or will I have to install V20 or whatever it is then. Also does the display need upgrading too?
I just installed the temp sensor. If your controller is 8 wire and has the throttle option it is simplier to install. If not you will need to solder some wires to the controller to enable.mscoot said:I see quite a few places recommending adding the temp sensor. Since my bike is heavy and I like to ride as fast as possible I suppose adding one would be smart. However, do I need a special controller for this? I only have the stock 36v controller that came with the motor in 2016.
Swapping the controller (in the motor) means a fair amount of dismantling. For me simpler to flash the existing. Ryan on the forum here (https://www.electrifybike.com/) may be able to assist for pre-programmed controllers and displays.mscoot said:Now, trying to wrap my head around the installation procedure, I think I have come to realize that I'd rather pay for a new controller and display with everything installed. Would this be a sensible way of doing this or are there other good reasons to install and flash it myself?
windburner said:I purchased a 750W 48V TSDZ and a 48V battery (which charges to 54.6V), and encountered the well reported overvoltage response from the TSDZ2...
casainho said:I am just waiting to be a father again and then have a reason to justify buy a Bullitt cargo bike like yours and also put TSDZ2 in it!!
Go to the wiki and read it, the information there is much more structured. Also go to the shops point there that sell TSDZ2 and displays with our OpenSource already installed, they have very good documentation on what are the advanced features, and trust them as this shops are runs by very experienced guys and they know what they say.
Good luck and enjoy riding your bicycles![]()
