nieles said:
casainho said:
So, since I remember, nieles is also a developer and user of our OpenSource firmware for Kunteng motor controllers. It is great to see his interest also on the motor since many things can be shared amoung the projects and that should speedup a lot any possible OpenSource firmware for TSDZ2 motor
well if we feel confident the software is portable (i.e. the right HW is there) i will probably buy a kit and get coding.
I see some strategic important points on this STDZ2 motor and controller that I also saw on Kunteng motor controllers:
1. for what users are saying, it is an relatively good mid drive motor
2. the most cheap on the market: starting at 300€
3. widely available: some well know online shops (BMSBAttery.com and http://www.pswpower.com/) sell them and ship to worldwide -- and this shops are selling similar products over the years so this product should be available on next 5 to 10 years
4. torque sensor: this type of sensor is really great but a typical one used on hub motors can't be used with mid drive motors, so, a mid drive motor that already includes one sensor is really a must
5. this shops also sell repair parts (http://www.pswpower.com/) at cheap prices, like the motor, the motor controller, the torque sensor, the gears (metal or plastic), etc. This is really important for users because of being able to repair and even adapt for specific needs. Also really important for development!!
6. potential to use as base our Flexible OpenSource software: since the microcontroller seems to be the same! this should boost a lot the development!!!
For all that reasons, I am pretty sure TSDZ2 will be a popular and good investment as a mid drive motor, available on the market for cheap on over the next 5 to 10 years. Also for the DIY modders/hackers perspective - that will even potentiate more the usage of this motor!!
I am afraid the original controller don't do "sinewave" control -- we need to check that!! Anyone saw any reference as this motor being running using "sinewave" control mode??
Because using sinewave/"very low resolution FOC" as on our firmware, we can get the motor running the most electrical efficient possible!! And that is really important to get the best range possible for the same battery pack!!
If original controller just do 6 step/block commutation, I will prefer to use instead a Kunteng motor controller that even has a very good LCD and Bluetooth module for using with a mobile app. Going by this path, only the torque sensor will needed to be tested as it is really different from the one of BMSBattery bottom bracket. All other things should be similar.
