hefest said:casainho said:TSDZ2 can sustain about 500W continuous if you ise a 52V battery.
This means it can sustain 9.5-10A continuous, I'm guessing. With 48V nominal that would be 450-480W.
I've got 48V 750W from PSWpower, and it states in the description that it is 15A motor. Is there a difference between this one and the one people are mentioning here as 18A max?
Hefest, did you ever find out more about the 18A version? I see that PSWPower lists both the 48V 500W & 750W as 15A but then there are other sellers with 18A versions.
http://recycles-ebike.com/tongsheng-tsdz2/95-tongsheng-motor-conversion-ebike-kittorque-sensor-48v-500w-42t-chainwheelwith-thumb-throttlecutoff-brake.html
And this post showing both versions together.
https://endless-sphere.com/forums/viewtopic.php?t=79788&start=1125#p1320280
Are the PSWPower ones in fact identical and the 500W is just limited by firmware?
