wpenner said:I have my motor apart, can someone kindly link me to a good diagram for installing the temperature sensor? I have the 8 wire throttle version. What three wires do I cut? Thanks, the diagram on the wiki is not super clear.
Sorry, I am not using KT-LCD3 no more so I can't say much.ri53hu said:Hi casainho, so I already started using Flexible OpenSource on my 8 pin 48v engine and 52v battery but I have a problem with making something I did but somehow I do not understand the submenu no time to come. Thank you for your work. Richard.
wpenner said:wpenner said:I have my motor apart, can someone kindly link me to a good diagram for installing the temperature sensor? I have the 8 wire throttle version. What three wires do I cut? Thanks, the diagram on the wiki is not super clear.
Cut the orange wire for the signal. Spliced into white wire for 5v, spliced into black wire for ground. I'll find out in the morning if it works.
wpenner said:Warning. It cost me $72CAD after duty and shipping to get a single blue gear shipped to me from pswpower. Consider ordering an extra gear if you are going to order this motor.
itchyfoot42 said:The 52V battery is a poor choice for the 15A version of the TDSZ2. Assuming the max charge for each cell to be 4.2V and the performance cliff voltage to be 3.35 a 13 cell 48V battery will have a fully charged voltage of 56.6. Full charge on my 52V battery is 58.8, BUT my 15A TDSZ2 will not start until discharged to about 55.5. On one occasion I got a start at 56V, but haven't been able to replicate that. The killer is that while both start at 55-56V, low voltage (out of usable power) is 46.9V for the 52V battery while it is 43.55 for the 48V battery. The 48V battery can be drawn down 13.5 volts, while my 52V battery can only be drawn down 8.7 volts, ALMOST 30% LESS!
I'm not an EE, so may not understand the impact of these numbers correctly, but it looks like my early adoption based on the then tribal wisdom that all 48volt motors should work on 52V has really reduced my range by 30%. I'm also assuming that a fully charged 48V battery at 56.6V actually starts the 48V TDSZ2.
famichiki said:itchyfoot42 said:The 52V battery is a poor choice for the 15A version of the TDSZ2. Assuming the max charge for each cell to be 4.2V and the performance cliff voltage to be 3.35 a 13 cell 48V battery will have a fully charged voltage of 56.6. Full charge on my 52V battery is 58.8, BUT my 15A TDSZ2 will not start until discharged to about 55.5. On one occasion I got a start at 56V, but haven't been able to replicate that. The killer is that while both start at 55-56V, low voltage (out of usable power) is 46.9V for the 52V battery while it is 43.55 for the 48V battery. The 48V battery can be drawn down 13.5 volts, while my 52V battery can only be drawn down 8.7 volts, ALMOST 30% LESS!
Is this reduced maximum usable voltage still a problem for 52V even after flashing the firmware?
wpenner said:famichiki said:Is this reduced maximum usable voltage still a problem for 52V even after flashing the firmware?
No, with custom firmware you can run 52V 14s pack and set low voltage cutoff to whatever you want. The original firmware will only start with a 48V 13s pack.
wpenner said:wpenner said:wpenner said:I have my motor apart, can someone kindly link me to a good diagram for installing the temperature sensor? I have the 8 wire throttle version. What three wires do I cut? Thanks, the diagram on the wiki is not super clear.
Well that did not work. Is the white wire not for +5v? Seems like it thinks the e brake is on now.
Regarding the bearings, please note that another bearing was found inside the black chassis.. perhaps in the version with one bearing at the left pedal.thineight said:casainho said:I want to put this info on the wiki, I will when someone share this.thineight said:Hello! Can anyone provide our motor's bearing codes?
I know there are few types on it.. in the main axle, on the blue gear axle, the sprag clutches..
Useful to be prepared in case of replacement :wink:
Many thanks.
I was asking the same info on the italian forum, luckily a user that recently was servicing the motor took note on all the bearings around.
Source: http://www.jobike.it/forum/topic.asp?TOPIC_ID=76426&whichpage=40
BLUE GEAR : HF1216 - 609 RS
Axle motor side 608RS – carter side 6001RS
Motore shaft carter side 696RS – motor side 6800RS
Main pedal shaft: left side 6902RS (61902 2RS1) – right side on torque sensor HK 2212 (note: on left side it is beneficial to put two bearings instead of one)
Sprag clutch: 30 CSK-P bb30 o CSK30P
Very useful to put this info on the wiki!
Note that my motors from late 2017 have already 2 bearings on the left side of the pedal shaft, whereas more recent ones looks they have one only. The user andrea_104kg recently added the second bearing right below the rubber protection and this helps to reduce the bending moment of the shaft.
Usually everything is insulated under that panel however you must check the battery power cable -- I suggest you to take out that panel to see by yourself.samuelsson87 said:I just bought my second motor from PSW but there seems to be a loose panel on the drive side where the cables goes.
Do I need to worry about water getting in?
See video on this link for better understanding: https://drive.google.com/file/d/1gf09u4ycKT_6gD4GjJQ2qiKbhWb6NhL4/view?usp=drivesdk
Henro said:wpenner said:wpenner said:wpenner said:I have my motor apart, can someone kindly link me to a good diagram for installing the temperature sensor? I have the 8 wire throttle version. What three wires do I cut? Thanks, the diagram on the wiki is not super clear.
I had similar issues installing the temperature sensor. My kit is from Electrify Bike Co, and has a bafang wiring harness, which uses different colors.
For me it turned out that blue was throttle and red was +5V. Black is still ground.
Inspect where your wires go very carefully.
More info on page 209 of this thread. Hope this sheds a little light.
wpenner said:famichiki said:itchyfoot42 said:The 52V battery is a poor choice for the 15A version of the TDSZ2. Assuming the max charge for each cell to be 4.2V and the performance cliff voltage to be 3.35 a 13 cell 48V battery will have a fully charged voltage of 56.6. Full charge on my 52V battery is 58.8, BUT my 15A TDSZ2 will not start until discharged to about 55.5. On one occasion I got a start at 56V, but haven't been able to replicate that. The killer is that while both start at 55-56V, low voltage (out of usable power) is 46.9V for the 52V battery while it is 43.55 for the 48V battery. The 48V battery can be drawn down 13.5 volts, while my 52V battery can only be drawn down 8.7 volts, ALMOST 30% LESS!
Zeggi said:Well with the firmware you can set it to your liking.
I'm using the 52v 750w version with battery; "14s4p 52v 14ah/17.5ah 500-1000w " Samsung 35ET
Max charged at 58.6-58.8v
Cut off set to I think it was 10-20% 46.3-47.6v
Power set to 750w
1. No as I didn't implement yet things like cruise control. But I think most of relevant features are there. I am still developing it.csbike said:Anyway, I have a few questions:
- are the features on the two displays the same?
- Will new features be available on both displays?
- is there a way to log statistics with either display? and possibly to download them to a PC later?
