JaiCee
- Joined
- May 6, 2019
- Messages
- 12
knutselmaaster said:Ah I see, you've got a 20" back wheel.
Maybe you could try a sram dual drive hub.
This has direct drive on 2nd, positive (136%) demultiplication on 1st and negative (73%) on 3rd if I remember correctly.
Yes it has a big impact on the speed. I've looked at hub gears and I'd like to try the cheaper option of switching chain rings first as my current rear wheel is 48H and no hub gear is close to that number. The current rear wheel is probably over built but it is also a big hassle to change the gear type.
