curly funk
🧲 New user
Hi guys,
The rain caught me while I was heading back home from work, and it was heavy. I decided to go full throttle until I got to my house. Unfortunately, a few kilometers from home, my motor stopped — no throttle response, no PAS.
I switched off the battery and pushed the bike home. Then I removed the battery and left it there. The next day, I took off the saddle to check what was happening with the controller. There was still water at the bottom of the box where the controller is located. I also noticed that the power cables to the motor were burned. I left the bike in the sun to dry thoroughly, and the next day I tried to cut off the burned parts of the cables and reconnect them, hoping it would fix the problem. No success.
What I saw was that my LCD shows no errors, but when I pull the brakes, there is no indication. The headlight and turn signals work fine. Anyway, I removed the battery again, and when I started pushing the bike back into the garage, the hub motor started making a rattling sound — it happens only when I push it backward. Then I unplugged the hub connector and saw that a few of the holes on the female part were slightly melted. I tested the thick male pins with a multimeter and got 0.00.
I've been riding bikes and motorcycles all my life, but I have no clue about electronics. Also, there is only one e-bike service shop near me, and I don’t really trust that they know what they’re doing. From what I’ve researched online, I think I will need to replace the LCD, controller, and hub. But if someone could give me instructions on how to properly test everything to see what is damaged and what isn’t, that would be great. Or if someone can suggest a kit to buy that won’t cost me a kidney, that would be awesome.
Thanks, guys!
Thanks, guys!
