OpenBafangTool - New Open-Source Bafang Configuration Tool
I don't know your situation, what exactly wrong in your settings
I have a bike with a Bafang M400 motor and I changed the cassette from 38 teeth to 46 teeth..but with a 46 tooth gear the motor doesn't run smoothly..I read on the internet that I need new firmware...?Thanks..
Sorry, I can not guess what exactly is wrong. Please buy converter, take screenshot of your parameters and post on this forum. Fortunatelly, for UART systems converter costs only 5$
Thanks for getting back on this. I have sent some inquiries to the manufacturer (Frey Bike). I will probably have to wait until the Lunar New Year holidays are over before I hear back.
Did you ever end up hearing back?
I'm trying to remove the throttle limitation on my m600.
If construction of your device lets remove cover and take photo of serial numbers without voiding warranty, please do it
if i take motor covers off and take photos of everything, can u try to assist me? i dont want to do with out ur consent to try and help. im no longer concerned about warranty of ebike as they are worthless on honoring ther sells, chinese . what can i say
Yes, I can try. Please make photo of your motor and I'll recognize if its actual bafang or other chinese brand
Did you get this to work ? And if so HOW ?????
I did, but bought a controller from Ado Air20 and integrated it into the Air20 Pro with the H700 hub motor. The only issue is that the connectors for the pedal assist between Ado Air and Air 20pro(and ultra) are different, so I could only have the throttle working, as I didn't want to change the whole assisted pedal mechanism. I integrated it externally, on a box and attached it to the bike.
The controller from Air20 (non pro version) does not run on a Bafang motor but on a Mi-Vince.
I couldn't find any secondary controllers using CAN BUS protocol with an unlocked firmware.
So, I'm still looking for a way to activate the throttle in the Bafang controller firmware settings with CAN BUS protocol, especially now with the new H730 Hub Motor from Bafang.
@AndreyPr, is that a way to help us with this one? What are your thoughts?
The H700/H730 has an integrated 3-geabox, we would like to add a throttle and unlock the 20KM to drive off-road. It runs on a small Bafang controller Home ADO Air 20 Pro | Ultra
Thank you
For uart systems you can use usual usb-uart converter. For can systems only besst tool is supported (canable pro will be added in future). Can you send me photo of your motor and connector?
Hi Andrey
I'm a noob to the Bafang eco system but have been following your thread for a while and was quite excited by your project as the chances of acquiring access to a BESST account seem pretty much impossible. In the meantime I was purchasing new parts for a DIY build that I'd been contemplating and researching for a few years.
I recently finished building the bike which is using the Bafang M560 motor and C245 v3 display system that unfortunately has almost all the tuning options greyed out, which is a little disappointing.
I tried to download the IOS version of the Bafang Go plus app but it appears that this version is no longer available, as I was only able to find the original Go app but not the plus version, which to my understanding is more suitable for the C245 v3 bluetooth enabled displays. However I don't think the bluetooth app would have unlocked the greyed out settings even if I'd been successful in finding and downloading it, which leads me to my question.
You mentioned that the Canable Pro USB interface Tool would be supported in the future to mitigate using the Bafang BESST Pro Tool... have you managed to implement this in later versions of your software as the Canable Tool would be a much cheaper (no account required) option of connecting to the system.... Many thanks in advance.
Thank you
Usually throttle is already available in firmware, but just require hardware trigger connected to specific connector. Sometimes it blocked in settings (by trigger 0% and 100% voltage parameters), in this case you can change this settings.
If there is no parameter of such kind, then its fully blocked on firmware level and I don't know what to do with it
Hi Andrey
Sorry, but for now development is stopped and no support of canable is planned
Thanks for getting back to me.
As no future support for canable is planned, would you advise purchasing the besst tool and use your software to unlock and adjust the greyed out motor options such as wheel diameter, power output in individual assistance modes etc?.....Thanks
Hi Andrey,
I have my first BBS 02 motor kit with CAN connector. Motor MM G340.750.C So far I have programmed the motors via UART. I bought a new CAN programming cable.
https://www.aliexpress.com/item/1005007821469593.html?spm=a2g0o.productlist.main.5.14e1zpw2zpw2wY&algo_pvid=dce74bb8-9259-45e4-8998-de15fd845d08&algo_exp_id=dce74bb8-9259-45e4-8998-de15fd845d08-4&pdp_ext_f={"order":"25"," eval%22%3A%221%22%7D&pdp_npi=4%40dis%21CZK%211516.63%21732.05%21%21%21490.66%21236.83%21%40211b653717493103751343135e4103%2112000042328497701%21sea%21CZ%210%21ABX&curPageLogUid=UC05mpDYRPzN&utparam-url=scene%3Asearch%7Cquery_from%3A
When I connect to the motor with a cable, I select CAN in the program, but I don't have the COM3 option. Only Demo. In the case of UART, I see COM3. Can you help me? Thank you very much.
Hi Andrey,
Hello.
Its basically not a converter at all. This chinese device is designed only to remove speed limit. I don't know why it has ch340 inside
Hello.
The device has 3 chips. CH340N, STM32F1 and SIT1050Q. I think this cable should be communication for CAN. So what cable should I use?
Only original Besst Tool is supported. There is no other supported converter
hey . can anyone tell me what can i change with this software and besst tool with m600 ? is this somewhat related to controller version or motor version ? I have m600 I purchased used and I'd like to change cutoff low voltage and faster current stop after I stop pedaling. is that possible ?
It depends on firmware of motor. No way to predict
Hello everyone,
First of all, I want to express my gratitude for this fantastic tool!
I’m currently trying to change the parameters of my BBS02B motor using a CAN cable I purchased from AliExpress (see attached). However, I’m encountering some issues. When I open the tool, the only mode available for selection is "Demo."
I’m using Ubuntu Linux and have followed the instructions provided on GitHub. Could it be that my cable is not compatible? Any insights or suggestions would be greatly appreciated!
Thank you!
*Edit*
Seems like someone asked the same question about the same cable some posts before. So the answer is, this cable does not work?
No it will not work. You need what is mentioned in post 194 if you like to use the program from AndreyPR and yes it cost some money. The device you show in your 2 pictures is a standalone device to change the speed and wheel size on Bafang canbus systems like the description probably mentioned. The USB A plug you put it in your PC but it's just to provide power to the device. Instead of plugging it in a PC you could also plug it in to a powerbank. The USB A from the device is not usable for communication with some programs on your pc trying to read the settings from the motor etc.
