JoltJockey
100 µW
Hello everyone,
I have been daydreaming, sketching and revising this Idea since about a year ago (but please feel free to give critical feedback, that's what I'm here for).
The idea:
The MTB: This LUTU aluminium 6061 full suspension frame will get a 200mm DH fork, front/ rear 29' 27.5*2.4in wheels. The welds look good at least from the outside and it is made with hydroforming. With 3.9kg on the heavier side but that is of little concern to me. I just hope it is strong.
Mounting: I want to do all mounting without drilling into the frame to avoid structurally weakening it. The battery pack will take up all the space in the main triangle only leaving space for the rear shock. A 14S 8P Samsung 50S battery is packed into a molded carbon fibre clamshell that has nylon straps embedded and "suspends" the pack from all sides. Since the clearance between shell and frame will only be ~1cm I expect this to he stiff enough + give the pack some extra isolation from impact forces.
Drivetrain: I plan to use brackets made of 3d printer carbon-nylon filament modeled after (plaster) prints of the frame. The brackets along the top tube will have cutouts that allow for titanium rods to be inserted which can be used as mounting points. Right behind the head tube where you can see the top tube and down tube welded together I want to have one big clamshell type bracket that will be the main support for the motor plate mounts. One Flipsky 63100 + 75200 vescs on each side. The drivetrain consists of three stages.
1st Stage: The motors (parallel to the frame) connect to a titanium shaft via a HTD 5M belt/ pulley system. The peak torque of the motors (18Nm combined) will be transferred onto the shaft (1.5:1 reduction = 27Nm total).
Stage two: The shaft ends at a jackshaft mounted before the seat tube reinforcement with a module 1.5 helical bevel gear to another bevel gear on the jackshaft with a 4:1 reduction (108Nm). Finally on this jackshaft is a 420 9T sprocket mounted - peaking 2-3 cm over the top tube with a chain going to a a 36T chainring mounted where the 6-bolt brake disc mounting point is. Along the way will be spring loaded tensioners (top and bottom) and chain guides to give a correct alignment with the rear sprocket and clear the seat-stay/ chain-stay.
(All drivetrain components aswell as the motors/VESC will have ventilated enclosures/ guards.)
My biggest worry: With this final reduction the peak torque along the chainline should be (24:1 total reduction) 432Nm in theory. Of course traction would break well before that but I feel very unsure about what magnitude of force I am exposing the seat tube/ beginning of top tube - area to. If this is would be within the design limits of a Trail/DH frame or the forces are simply too much and from a direction that MTB frames are not designed for.
So tat's where I am at the moment. I expect things will break during testing but as long as it is limited to clearance, overheating, mounting I think I'll find solutions. When it comes to the load on and limits of the frame I'm still in the dark.
Note on rear braking and clearance: I plan to put a 142TA hub on this 148mm dropout. shifting the hub to the right so that the left side now has 6mm of extra clearance. If this isn't enough the XD hub due to it's compact size should allow me to grind away a couple extra mm from the right hub cap. To center the wheel I will adjust the spoke tension accordingly and the exposed Thru Axle space will be occupied by washers.
For braking I plan to use motor braking + either modifying a hydraulic brake to be able to clamp onto the chainring or mount a V-Brake that can grip onto it. Ideally I can make enough room to only have to adjust the brake mounting point and be able to have it function with the disc brake as it should.
If you have ideas, inputs, critical feedback that you can share I'm super thankful. Or maybe someone knows of a very similar successful DIY project out there that I just haven't found yet.
Have a great day, I wish you all smooth riding!
The idea:
