It was too cold today to continue patching rust on my roof this weekend so time for bikes...
I've been too busy for too long and this bike has sat neglected in my shed...
Finally dug it out of the shed and dusted it off.
I want to use it as a test mule for my controller but first of all I wanted to get it up and running quickly at a lower power level so my plans are.
1) Add a cyclone kit and prove its working
2) setup the cyclone kit to run on my controller to get some test time under real loades.
3) get back to the mechanical parts of the RC drive so I can really push my controller to its limits.
4) when the RC drive is reliable ditch the cyclone to save weight.
I should be able to leave the cyclone kit on the bike as a limp home mode if the more experimental stuff fails...
My employer is building an new building that means I will have to commute approx 7Km to work compared to my 2.5Km I have now so a backup plan seems like a good idea. This is also the reason for getting a cyclone for this bike as this bike is going to be a backup for my main bike.
The cyclone kit I got is the 3 chainwheel 250W. Didn't really matter which one I got but a 250W label is nice for compliance reasons :lol:. The 250W internal controller will allow me to be confident that the chains are all aligned and then It will get the conversion to external controller... I'll make a harness so I can use my controller or a 48V ecrazyman.
I'll have to dial the wick right down on my controller though to avoid vaporising the phase windings in the cyclone :lol:.
I have fitted the cyclone kit as below
Those tires won't be staying...
I have run the cyclone up on one of my 8s2p Turnigy packs and its running quite smooth. It seems quieter than my elation V2 ever was (same motor/gearbox type though). The chains seem to be aligned well.
One nice thing is the cyclone throttle is quite linear and runs at low speed compared to my cheapy throttle on the ecrazyman controller on my other bike( probably combined controller and throttle effects). The throttle on the cyclone is good in that although it looks the same as the one on the elation v2 kit it doesn't have the stupid stepped ramping up of speed the elation one had.
I'm going to use a magura anyway so apart from initial test the cyclone throttle will go in the parts bin until I find someone who needs one.
I got the heatsinks with my cyclone and they give a big hose clamp to hold them i guess but I want to glue them on so need to find some good cheap thermal epoxy I guess.
I'm planning to swap the gear cables to a black ones for aesthetic reasons only. I have removed the V brake from the back as I'm relatively confident of fitting the chain drive and disk brake on the same side at the same time when I get there.
The bike is now running Avid elixer R 203mm front and rear.
So far I think the 3 chain wheel cyclone is better than the elation V2 that has 3 chainwheels plus one for the motor.
The loss of one gear which you don't need anyway on the cyclone means that the cranks don't need to be weakened by stupid bends so should be less flexie as well.
Looking at things I may even be able to go for a slightly shorter BB than the asymmetric one supplied in the cyclone kit. It has about 20mm more clearance of the motor than necessary.
The photos below show that I should have plenty of room for different battery combinations. There is still room below the one below the top bar for a 4s 10Ah brick so alll up If should be possible go put equivalent of 3 * 8S 10Ah and a 4s 10Ah or that number cells in different configurations comfortable. The suspension and wheel will clear the one below the frame if it becomes necessary to have a pack there although I would prefer not to hang a battery in such a vulnerable position.
I'm just waiting from some LED indicators and control switches to arrive and then I'll lock down everything on the handle bars.
