Arlo,Arlo1 said:Miles the spread sheet lost the weight of the leaf motor its 123 lbs.
I will try to get some no load current later today.
When I hover my cursor over the ### it shows it... Why is there a ### in place of the weight?Miles said:Arlo,Arlo1 said:Miles the spread sheet lost the weight of the leaf motor its 123 lbs.
Unless something happened with your copy of the spreadsheet, it's in there as 55.8kg :wink:
You get it when the figure (with req. no. of decimal places) won't fit in the column width. It would be odd if this was system dependent..... You're using the Excel version?Arlo1 said:When I hover my cursor over the ### it shows it... Why is there a ### in place of the weight?
Punx0r said:Take a look at Justin_le's post above on Dec 19th. The first chart shows a fast and slow wind motor on the same controller and current limit, with the slow wind having about a 10% torque advantage upto ~18kph, then a serious disadvantage after that.
The second chart shows the effect of reducing the controller and wiring resistance on the controller for the fast wind (but keeping the same current limit), which removes this low-speed torque advantage, leaving both motors equal upto @18kph and the fast wind having the advantage after that.
Punx0r said:Interesting because that's very slow indeed.
John, as to why the fast wind motor makes less and less torque compared to the slow wind motor as speed increases, my assumption was that the fast wind motor just isn't drawing all the current that's available, whereas the low speed wind is still bumping up against the current limit. I'd speculate this was to do with the higher resistance/impedance of the motor winding and possibly it's interaction with the source (controller/cable) impedance. I say speculate because I'm unsure whether we're dealing with AC or DC: The motor "sees" DC, but the controller pumps out AC. If we're talking AC then we possibly have a situation of load-matching determining power transfer to the motor. I agree it would be great to have a proper answer from someone who knows![]()
Squirts of DC that alternates so Squirts of AC....sn0wchyld said:To answer other points...
the motor only ever sees AC, though really its AC made up of lots of little 'squirts' of DC...
A better description would be squirts of DC (directed to phase coils) which are made up of quicker squirts of DC. It has essentially nothing to do with the conventional definition of alternating current.Arlo1 said:Squirts of DC that alternates so Squirts of AC....sn0wchyld said:To answer other points...
Miles said:The end turn losses are constant for different winds. The only thing that varies is the relative resistance of the section of copper between the coils as this changes in cross-section but not in length...miuan said:3. low number of turns usually means more interconnections between teeth and more end turn copper losses. As a result the fast motors heat more.
teslanv said:So now that we know that lower-turn count motors are capable of handling more current, and thus providing similar torque output as higher-turn count motors, let's talk about what appropriate Phase current settings would be for various winds to realize this similar performance.
Let's say I have a Xie Chang 18 FET controller, and Assume a maximum rated (battery) current of 60A, and 72V nominal battery for 4320 Watts of battery power.
And let's compare the winding options of the MXUS 45mm DD Hub motor:
Would this be an accurate chart of similar torque outputs between various winding counts and Phase Currents?
21x3-Turn Wind (12 Kv): 240A --> (11.43A per strand)
16X4-Turn Wind (9 Kv): 180A --> (11.25A per strand)
12x5-Turn Wind (7.2 Kv): 144A --> (12.00A per strand)
10X6-Turn Wind (6 KV): 120A --> (12.00A per strand)
9X7-Turn Wind (5.1 Kv): 103A --> (11.43A per strand)
8X8-Turn Wind (4.5 Kv): 90A --> (11.25A per strand)
7X9-Turn Wind (4 Kv): 80A --> (11.43A per strand)
6X10-Turn Wind (3.6 Kv): 72A --> (12.00A per strand)
5X12-Turn Wind (3 Kv): 60A --> (12.00A per strand)
