e-beach
Yea throw this thread on the pile of "Tube Protector Slices Inner Tube" stories.
I think I am done with tube protectors for now. 2 of my 5 last flats were caused by tube protectors. I was unsure if the first one was due to improper installation so this time I took great care to do it right.
This time I pressed the new tube in a way to flatten it out and then put the Slime tube liner over the tube and centered it on the tube. I marked the tube with a silver Sharpe marker so when I enstalled the tube protector I would get it centered over the tube. I then continued to mark the tube where the edge of the tube protector should follow.
I then put the tube liner in a bucket of warm water and put it into the sun for a while to soften it up a bit for installation.
I put the tube on the rim and inflated it just enough to give it proper shape. After about 20 minutes I pulled the tube protector from the water, dried it and inserted it between the inside of the tire and the tube. I got it extremely well centered by using the silver line I drew on the tube.
And the result? After less then 150 miles the tire liner had sliced a hole in my new Giant extra thick inner tube.
The only fortunate thing about this story is that I was home when the tire went flat.
As you can see by the picture the slice was dead on the centering stripe I put on the side of the tube to match the side of the tube protector. (the lightish looking strip where the tube was sliced.) So this time I am very well satisfied that I did every thing right. And the tube protector malfunctioned.
