I don't think that this issue is fully solved. It seems like Arlo was really onto something in his last post.
For those thinking about using a 12 fet with a 3220, some more research might be in order.
I had good result on the bench at first with my new lyen modded 4110 12 fet and a sensored 4t 3220 and for the first few runs, it did ok on the bike too. I had the bike geared too high so acceleration wasn't too great but between 15 and 45ish was pretty fun and the controller was pulling 40 battery amps, measured on the CA through a calibrated shunt. I got a new drive sprocket and reduced the gearing to a 30mph top speed and went on a run and the controller started cutting out when I rolled on the throttle. At first, I could roll it on slower and get up to top speed but after a few runs up and down the block, movement of the throttle would just make the motor spin up for a second then shut down. I took the controller apart and everything looked and smelled perfectly fine inside. No fets were shorted and there was no evidence of anything overheating. The controller got warm to the touch while it worked but I could hold my hand on it so it wasn't too hot. So I put it back together and thought I'd reprogram it, maybe drop the lvc and current limits a little in case they're off or something......I tried everything, including block time, using up to an eb-36 board setting, every combination of phase currents, etc. I've thoroughly checked the motor wiring, throttle, monitored for voltage stability during the cutouts, checked battery connections, etc. At the time of the pics, everything was hooked up with crappy 30A crimp automotive connectors and 45A andersons but it's all been changed to 8 gauge wire with big castle bullets since.....and the controller still cuts out.
So with everything I could think of done in the programming and after checking out everything else on the bike out, it was time to go inside the controller and do some work. I've wanted to do some real upgrades to it for a while now but haven't really had the time. Rather than mess with it for much longer, I decided to give it everything I've got and just build a good controller out of it. I started by adding a 500 ohm resistor across c20. Tested it....still cut out. Then I increased r43 in six stages all the way up to 47k....tested it....still cut out. The next step was to remove QF1. That's a tiny little booger! The controller still cut out when rolling on the throttle with very conservative settings so I took it apart again, pulled the fets from the board and tested them, tested the caps(as best as I could), added a couple of extra shunts, modified the board to accept some really nice 8 gauge power wires. I left the ten...ish gauge phase wires because I didn't really have an appropriate replacement and the wires going into the 3220 aren't any bigger. I also ran lines in to the speed switch taps. And best of all, I went nuts with the soldering iron and solder wick and really beefed up the board traces. I noticed two traces on top that I haven't seen anyone else pay attention to that feed power to two of the fets so I built them up a bit too by drilling a small hole next to the fet leg and running a few strands of the braid up through it, then soldering it to the board on top.
I set the programming as an eb-36(4 shunts right?), set battery current to 30 and phase to 75 and took it for a spin. All of a sudden it's definitely a much more interesting controller, almost lifting the front wheel before.......it cuts out and I have to let off the throttle to reset it and ease it back on. So far, in a few runs, I did one 2600 watt pull from 10 to 30 that was pretty cool but the cut out thing is terrible.
Anyway, here are some pics I took of the bike before I started today. I wanted to get some in case I got too fed up with the controller and decided not to mess with putting it back together! I also swore I'd never build a bike with a bunch of duct tape but there's wood under it at least and it's only temporary until I build a nice battery box for it :wink:
If someone's already figured out the cutout thing and I've just missed it, please let me know. I've searched and soldered my eyes out.
Should I even bother putting QF1 back in there? It obviously doesn't have anything to do with the problems I'm experiencing.
Here are some pics:
