Speedict has launched new product, which is BMS ? able to live view 13 multi-chemistry battery cells + balance, support both iOS and Android now ...
rosich said:Speedict has launched new product, which is BMS ? able to live view 13 multi-chemistry battery cells + balance, support both iOS and Android now ...
megacycle said:Can 2x BMS be seriesed, for 20S?
That would be okay for me if the 2 neptunes screens can be viewed alternately.speedict said:megacycle said:Can 2x BMS be seriesed, for 20S?
it is not with stacking feature, when connect 20s with 2 x neptunes, you only able to live view 10s group at a time.
Despite my post over on Pedelecs I might well give it a go, but I don't know if you can order the Neptune Guard board yet. The price on the website is just for the Neptune cell monitor / balancer, the Neptune Guard will be roughly €49. I see from this thread that the Neptune Guard board includes a Coulomb counter and soft switch, both of which would be useful.d8veh said:I'm going to give one a try. It's really good timing because I've just ordered a load of cells to build my next battery, which will be 13S. I'll give a full report when I get it.
Who's going to be first to get one up and running?
mfj197 said:Despite my post over on Pedelecs I might well give it a go, but I don't know if you can order the Neptune Guard board yet. The price on the website is just for the Neptune cell monitor / balancer, the Neptune Guard will be roughly €49. I see from this thread that the Neptune Guard board includes a Coulomb counter and soft switch, both of which would be useful.
D8veh, you've used a lot of their things. The Neptune website states the connector to the balance wires is via a PH 2.0 connector, i.e. 2mm pitch. Is this usual for them? It would be a little annoying as I've just put on an 11-way JST-XH (2.5mm pitch) plug onto my pack for balance charging!
Michael
speedict said:it is not with stacking feature, when connect 20s with 2 x neptunes, you only able to live view 10s group at a time.megacycle said:Can 2x BMS be seriesed, for 20S?
megacycle said:Any chance of answering these questions-
Is there an operating manual?
What is the maximum through current?
and the maximum cell balancing current?
are the cell voltages programmable, eg like 3.60V instead of 3.65V for Lifepo4 ?
DaDo.Bzz said:Hello Speedict
I would like to buy your new product. Have few questions
1. When you starting to ship?
2. I dont see energy consumption per km also no estimated range. How come? I think this is the most usefull info for mist users. Will you plan to implement also these function? (Is it possible to attach speed sensor to Neptune, to have it accurate also when phone and gps is off. You can implement also autocalibration.) Would be nice to have chart like in Lexus of kilometer consumption per last 10 km.
3. I dont see Neptun Guard on your page. Or am I blind?)
Cheers
Thanks for the info.rosich said:>>>> and the maximum cell balancing current?
~3mA to 5mA
yes
megacycle said:Thanks for the info.rosich said:>>>> and the maximum cell balancing current?
~3mA to 5mA
yes
It sounds likes it's not suitable for my kW fast charging requirements, where balancing currents could be much higher.
I often get a half-dozen or so spurious high or low readings in a 30 minute trip. This results in meaningless max and min values but it doesn't affect average values and integrated values (Ah and Wh) since the're such a small proportion of the total. When I look at the plots of V and I vs time, it all looks right except for these rare spikes.knutselmaaster said:I wouldn't let a Speedict product manage my battery charge.
The readings are often totally off, imagine it doesn't cut off at full/empty....
Look what it reads from a 36v system with a 14A controllercontroller and no regen (geared hub):
