I disconnected everything but vms CAN - 13 frames only
0x71F is a frame which bms sending request to VMS
one of rest of them is probably an answer to it - but still even if you able co copy this signal - it might work but probably bms need to get other data all the time
as I said before - its only depend how complex stiga system is - if its simple you can figure it out I think in 1-2 days, if its need signals all the time it can take weeks/months
good thing is you get 48V right away after you switch it on - so even if vms or traction controller is completly burned you still can add your own controllers to run it
I hope you can figure sth out and share it with us
