sergiosmvc
100 µW
- Joined
- Sep 5, 2022
- Messages
- 7
Hello,
I installed this weekend a kit from CSC with a 500w 36v motor and a sw900 display and i have 2 problems:
The first problem is that when i connect the battery cable, with the sw900 turned off if i use the throtle the wheel spins. And if i try to turn off the display, it remains always on saying OFF with the backlight on. I searched here on this forum and a user said to check the blue and red pin to check if there is continuity. And those wires are shorted. Is really the SW900 display that is broken?
The second problem is the speedometer. The display was setted from the factory with the P07 = 1 and with this setting the speed is always at 0. Then if i change to any number for example 68 i got speed reading... but i got only the speed reading if i use the motor. If i set the PAS to 0 or if i don't need to use the motor the speed is always 0...
Can you help me?
Can you help me?
