WW was probably already closed by then, though I guess I could've had you bring my own stuff to me rather than my brother.
I definitely appreciate the offer of future assistance if it's ever needed.
FWIW, these moped tires and tubes have been so much more reliable than bicycle versions that even without slime or protector strips, etc., I've run them for more than a year now (long enough to forget when I started) with no issues except that caused by a huge piece of debris across a lane (probably the big beam behind a truck or big car bumper, couldn't really tell at the time). I guess it's made me complacent.
Bicycle tires have been problematic pretty much the entire time I've been doing the cargo bike thing, requiring slime, protector strips, double tires and/or tubes (old ones sliced and placed as "liners" between tube and tire)--at least one of those and sometimes all of them, just for my regular commutes.
Back in my regular bicycle days I still needed at least the slime and strips.
And regardless of what I used, I'd still have to carry extra tubes, because stem failure or seam failure due to crappy tube manufacturing has always been an even worse problem than the actual road-debris-caused flats.
Since my goal is to ride without stopping to fix flats, because it sucks having to always head out up to an hour early anywhere I go just to ensure I am not late in the event of a failure. I tend to always allow a little extra time for whatever traffic delays/etc might come up, but that extra time every day adds up to a lot of time wasted for no good reason, if a preventive measure would negate the need for it.
Hence, the moped stuff. Still bicycle tire/tube on the front, but it's not usually the front that gets a flat, even on this monster. Had a few on CrazyBIke2, all stem failures IIRC, though there was one where the stop I had to make due to a car doing a stupid maneuver skidded the already-worn front tire enough to rip thru it and down to the tube; I think the tube survived but was damaged. Been a long while since then, so would have to dig up the post about it for details.
Anyway, the moped stuff, 16" types (20" bicycle equivalent), has been way better quality even with the cheap tubes. I do need to find and get some more tubes for spares, just for this eventuality, and I also need to get a new patch kit (I cannot find the one I presumably took out of the seatbox; it's not in pieces in the doggie-poo areas either, so Kirin and Yogi didn't eat it. :lol: )
I was thinking about the air pump and stuff, and am considering mounting it's guts underneath the trike's cargo deck, between the controllers, wiring into the lighting system directly, and then just keeping an extension air hose from it's kinda short one to reach the rear tires. I'd ahve to take the front wheel off to reach it, but that's not a big deal compared to the rear.
Most of the time to fix the rears I'd have to roll the trike on it's side anyway (assuming no dog or cargo in the back), so easy enough to reach the pump there, too. Then I'll ahve the "good" pump on the trike without using up cargo space in the seatbox.
