Hi everyone!
I recently got a TDSZ2 VLCD5 500Wa 48v12Ah to bring my son uphill from the kindergarten. Installing the motor was an adventure and I sweated plenty (had to bring out the saw twice
) but it now works and I’m overall happy. However while I had zero experience with e-bikes I could tell this motor was not possibly giving me all it had. Doing some research online I found this board- woohoo! I’ve just ordered a STLINK V2 and I’m very excited to try and “flash” the motor. I have a couple of very dumb newbie questions that I’m hoping some kind soul can answer.
-do I need to flash both, the display and the motor? Will I need any other cable besides the stlinkv2?
-I’m planning to install the open source version. How do I know which file/version do I need?
-once I’m “in the system”, how do I know what “numbers” or “parameters” should I enter? I basically want the bike to start assisting right away and not after half a pedal, assist a little more and perhaps be a little more quiet.
I would NOT recommend having the assist start immediately - especially if you have a Toddler on board. Did you purchase the brakes with motor cut-off sensor ? Worthwhile if you ever experience problems with motor surging
-perhaps should I try one of the pre-made versions? How do I know which one to install?
See Link below for latest firmware
-Edit to add: I’m scared of “frying” the motor. Are there settings I can install to avoid this, without having to add additional cables to the bike?
If you mean will the STlink "Fry" the motor - No it uses only 5V from USB. If you mean will the extra power available from OSF fry motor - No, if you stick to conservative setting eg Amps =15 Total watts=500 Speed Limit 25Km. Also use bike gears to assist the motor when climbing hills.
I’m not a computers person so I apologize for potential incorrect terminology... this is a big stretch for me, but I know it will be worth it! Anyone can recommend a very step by step fool proof guide or YouTube video that covers the motor and the display?
https://github.com/emmebrusa/TSDZ2-Smart-EBike-1/wiki. Download the zip file it contains everything including PDFs showing all the settings and how to use them. They are not the best manuals so read them several times
Thanks so much for any guidance!
