jbalat
All the top end ebikes go to 120 cadence. I can't remember ever topping out on my trek powerfly yet I have topped out rpm on my tsdz2 many times. So please aim for 120 as a maximum
Ok so probably I will reduce the PWM frequency for 115 max cadence then reduce a bit the efficiency for up to 120 RPM and then TSDZ2 will be on pair to top end ebikes. Currently this can only be achieved with like a 48V battery for the 36V motor and maybe the 60V 15S batteries. I hope to get the field weaking working and then I hope this will improve for same battery and motor voltage.jbalat said:All the top end ebikes go to 120 cadence. I can't remember ever topping out on my trek powerfly yet I have topped out rpm on my tsdz2 many times. So please aim for 120 as a maximum
Waynemarlow said:I don't want to influence you but my guess would be that very very very few riders on this forum, would be able to push into the 100's for any thing more than a few seconds, let alone run regularly ride in that 100 - 110 bracket. That's for the fitties among us and my guess those fitties are probably riding non Ebikes more often than not to be able to pull those rpm's.
bikesnobyyc said:jbalat said:All the top end ebikes go to 120 cadence. I can't remember ever topping out on my trek powerfly yet I have topped out rpm on my tsdz2 many times. So please aim for 120 as a maximum
I would echo this comment. I ride a TSDZ2 fat bike on winter trails and the motor will lose power partway up short steep ascents as it goes past 90RPM. Momentary RPMs of 115-120 would be a big benefit as you can't realistically shift gears under full load in these situations. For now, I just make sure I gear down a lot before even approaching a steep hill, but that really slows down the initial part of the climb. I could see the added RPM also being really useful in any future eMTB implementation. I also ride a 2019 Specialized Turbo Levo and it handles the short high-RPM bursts flawlessly... it's really nice to have.
vshitikov said:bikesnobyyc said:jbalat said:All the top end ebikes go to 120 cadence. I can't remember ever topping out on my trek powerfly yet I have topped out rpm on my tsdz2 many times. So please aim for 120 as a maximum
Wow I just checked, turbo levo motor and for that price of ebike and a motor I will carry you on my back on those steep hills
16A tiny motor will not work as 0.5kW heavy duty motor that can absorb those peaks from battery. It will overheat ... there is no magic - a motor rotating at 90RPM and providing torque will heat up and damage itself quickly as you have to dissipate these power losses.
casainho said:You guys get ready to try the field weakening!! I will soon do a release:
This were quick tests with constant load (bike training):
No field weaking: motor speeds erps: 543, battery voltage: 57V, battery current: 3.6A, motor power: 205 watts
Field weaking: motor speeds erps: 678, battery voltage: 57V, battery current: 5.6A, motor power: 320 watts
So, the field weakening were able to increase motor speed / pedal cadence by 125% but the with an increase of battery current / motor power of 155%. Since the load was the same but the speed did increase, in fact, the loss of efficiency is 24% only!!!
(Please check the math, I may did some errors)
AZUR said:Hi,
On the screens below, taken from a Garmin 1000 edge, you can see the human power and cadence, sent from TurboLevo to Garmin. The data refer to an activity carried out on 15 March.
Thanks for sharing. I think the only metric missing on our firmware is the consumption in Wh/km, which I plan to implement soon with the Field Weakening feature.AZUR said:Hi,
Order one and tell us about what's inside, make pictures! The stock firmware is not that bad and you can still ride your bike even you may not have all the bells and whistles of the OSF.Danielwj said:Has anyone yet tried to flash on of the
New 2020 versions of Tsdz2. I’m a little worried about ordering without knowing if it will work.
vshitikov said:Order one and tell us about what's inside, make pictures! The stock firmware is not that bad and you can still ride your bike even you may not have all the bells and whistles of the OSF.Danielwj said:Has anyone yet tried to flash on of the
Danielwj said:vshitikov said:Order one and tell us about what's inside, make pictures! The stock firmware is not that bad and you can still ride your bike even you may not have all the bells and whistles of the OSF.Danielwj said:Has anyone yet tried to flash on of the
Its a great plan, but I was planing to do a 36v motor on the 48v battery, that's not possible with the stock firmware
casainho said:I went to the street to test the development firmware for the field weakening and it is amazing!!
So, as you can see, the motor was pulling from battery 7x more power but for the measures I did, it is less efficient when field weakening get's automatically activated at high cadence, by 25% less eficient. So, only 400W, which means that with field weakening I got 570% more motor assist at near the limit of 120RPM cadence!!
Have you bicycles ready because I will release in some hours a new firmware version!!
That is why will be possible to disable field weakening. Also I will implement the battery power usage per km, Wh/km, so you as a user will be able the evaluate what works better for you. And I wish to document this information, how the motor works, etc, so users can take more informed decisions.Waynemarlow said:That sounds really good Casainho, if we are losing 25% efficiency that's a huge penalty re ride time for our existing batteries ( battery size may need to be bigger ) + wheres that loss of efficiency going, heat ? Sounds as though we maybe into the situation of running 48 volt engines rather than the 36 volts we have all been running on 52 volt to get the higher cadence and having to run bigger battery packs to cover the same distance + the extra weight all because we want the benefit of a higher cadence.
OK I would run with it but I run a 360WH 14S2P pack which just is spot on for the 35km 650m climb run I do, but 25% losses, that's going to really mess with that combination
Look forward to trying it.
