Allex
Who needs 2.5 when you have 3.5 cells now. = 31 x 3,5 = 108 Ah -> 74 x 108 = 7990 Wh
Agreed, I was just checking the cheapest configurationAllex said:Who needs 2.5 when you have 3.5 cells now. = 31 x 3,5 = 108 Ah -> 74 x 108 = 7990 Wh
Allex said:20s31p 620pcs fits in the vector.
Vector battery:
2.775Wh
14,9kg
2,9Ah
3,7v
20s = 74v-84v
15p = 37,5Ah
300 cells
9,25Wh/cell
186,24h/kg
consumption of about 41,5 - 46 Wh/km (?)
==> Range of 60-66,8km. (Depends on ridingstyle)
My battery to compare:
3.726Wh
20kg (My capacity / vector battery kWh x 14,9kg as I don´t know the weight of mine)
3,45Ah
3,6v
20s = 72v-84v
15p = 51,75Ah
300 cells
12,42Wh/cell
186,2Wh/kg (same)
==> 80-90km.
Allex Monsterbattery:
7.700,4Wh
43,14kg
3,45Ah
3,6v
20s = 72 - 84v
31p = 106,95Ah
620 cells
12,42Wh/cell
186,2Wh/kg (same again)
~180kg range
(consumption is different when accellerating = more weight. To keep same speed same consumption)
MONSTER SUPER DUPER BATTERY (Allex´s x 2)
~~~~~~~340 - 350km
DasDouble said:Just imagine the Vector frame would be just a little bit wider and you coud put two of these baby near each other :lol:
#good bye my old friend socket, I will see you next year![]()
Artur said:DasDouble said:Just imagine the Vector frame would be just a little bit wider and you coud put two of these baby near each other :lol:
What the problem to use our 3D shaped side covers? 170mm wide inner space. Hello?
Quokka said:What is the silicon between the Ps for? Is that just a mechanical barrier for the ends of the copper wire?
DasDouble said:Artur said:DasDouble said:Just imagine the Vector frame would be just a little bit wider and you coud put two of these baby near each other :lol:
This would add 82kg of battery if you take panasonic PF cells. Max load of stock frame is 150kg+14,9kg of stock battery which got replaced by the heavy one. = To not risk to bend the frame you would need to weight less then 82kg.
Ok you are correct, already possible with 3D side covers. I thought they are too small but I was wrong, my fault![]()
Artur said:DasDouble said:Artur said:DasDouble said:Just imagine the Vector frame would be just a little bit wider and you coud put two of these baby near each other :lol:
This 150kg info is just for paper...
I was riding my bike with my dad together. Total weight of two riders was 160kg! This is just riders! So if you going to ride alone, you can put as big battery as you only can imagine. .
DasDouble said:I am still missing the second passenger foot pegs. Has the girl on the pic something like a foot peg for her feed or does she put it on top of the motorscrews???![]()
Edit: Oh man, this guy´s poor legs.. No right shoes to ride, but a armor jacket :lol: ^^ Seems legit
Edit 2: Artur will you ever sell something where the passenger can put his hands on? Or do I have to build such thing by my own somehow?![]()
NoFanBoiz said:Quokka said:What is the silicon between the Ps for? Is that just a mechanical barrier for the ends of the copper wire?
The engineer in me says it's for strength and to stop movement between the pack joins. All other areas have some strength and lack of movement built in due to the solder joins between the batteries.
DasDouble said:Edit 2: Artur will you ever sell something where the passenger can put his hands on? Or do I have to build such thing by my own somehow?![]()
Thx heaps mcribs... i am getting that itch again...macribs said:There you go Quokka, the convex side covers from Vector.
