larsb
It would certainly help if the picture was readable. Or turned.
larsb said:It would certainly help if the picture was readable. Or turned.
larsb said:I’ve seen hall fault shown randomly but what it means is that there’s an error caused by the throttle.
Either
Throttle not connected correctly (or broken)
or
high volt error or low volt error caused by set throttle limits that are not met by throttle.
Hi BartoshBartosh said:tylerwatts said:Ok but I asked about an EM150SP Vs Nucular 24F. Is the Votol better value then and plenty controller for the job (so to speak)?larsb said:Might be dependent on your available space, the votol EM300 is a bit of a brick but much more powerful at the same price as a nucular.
Someone has to take the plunge and buy it![]()
Cheers
Tyler
I can't say until I'm done testing Nucular. I've been having some problems making it work at 300bA/500pA with my qs 138 70h middrive though. There are some weird cutouts, still WiP, need a week or two, it may be a hw failure or may be not, no way to tell at the moment. I might have found a solution but need more time to test it.
What I can confirm, Votol can't be beaten if it comes to standstill response, this thing is like twice as snappy on WOT from 0RPM. Can't make the Nuc work equally well in this regard. Both controllers can be overheated quite easily. I'll post more as soon as I have a stable setup to play with.
Thanks larsb, I'll have a look. Either that or run an EM300 at lower settings, possibly better than cooking an EM150...larsb said:There are water cooling blocks for the votols on taobao and simple enough to do diy.
rexfordk83 said:im about to do a test run on my setup, 138 motor and em150sp controller. do I need a switch for the 3 speed functions? what if I just want it in the best performance mode all the time, would that be sport mode? and do I need any type of switch for that or can It stay on every time the unit is powered on?
bayareametalfab said:Hi Guys i just wired up or thought I did a EM 150sp and I can't for the life of me get it to turn on. What connections are required to get it to turn on? Are the Alarm connections required to turn the unit on? e-Lock is connected to the battery directly.
SilverLine said:bayareametalfab said:Hi Guys i just wired up or thought I did a EM 150sp and I can't for the life of me get it to turn on. What connections are required to get it to turn on? Are the Alarm connections required to turn the unit on? e-Lock is connected to the battery directly.
Check the display page in the gui, to se if its in Park mode. If it is, search this thread to get the solution.
bayareametalfab said:SilverLine said:bayareametalfab said:Hi Guys i just wired up or thought I did a EM 150sp and I can't for the life of me get it to turn on. What connections are required to get it to turn on? Are the Alarm connections required to turn the unit on? e-Lock is connected to the battery directly.
The software won't connect to the controller I'm getting that error.
SilverLine said:bayareametalfab said:SilverLine said:bayareametalfab said:Hi Guys i just wired up or thought I did a EM 150sp and I can't for the life of me get it to turn on. What connections are required to get it to turn on? Are the Alarm connections required to turn the unit on? e-Lock is connected to the battery directly.
If its the Sp version, remember to tick "Can enabled" and power the controller from the battery.
