rexfordk83 said:
SilverLine said:
rexfordk83 said:
I just got my em150sp and qs138 motor connected to the software. Here is a pic of my throttle settings. when I twist throttle the motor doesn't move until about 1/4 turn of throttle. Is there any adjustment so it is more sensitive? and how do I know that it recognizes what full throttle is when it is fully twisted?
also can you share with a few parameters to change to get full performance out of box? like I disable soft start! I can raise bus current to like 180. to get in sport mode I tried to take yellow/white wire and put it to the ground wire, but I cant seem to change the mode in software under gears, seem to stay on H. any help would be great, thanks
You measure your voltage output from you throttle, when going minimum and maximum, when 5v is connected from the controller. Typically with a 5kohm throttle.... it goes between 0.2v to 5v.... mine is around that. But I like a little deadband in the bottom, so my start voltage is set at 0.8v
When yellow/white is connected to GND, dosnt the gear show as "S" under the Display page in the software ??
so on sport mode yes, I just got it to switch by touching it with ground, but now I seem to run into more issues. I noticed on page one my model was set to em 100 so I put it to em150 and saved. I then noticed it wont even get recognized by the software now. I tried it with the older can bus version software and it recognizes it but has all faults codes. and then was able to get back into the main software and has a lot of faults and my throttle setting went all to zero. I re entered them as original and saved but nothing. im having trouble getting the software to connect and now the motor doesn't even spin when I try to twist the throttle , I can hear a hum like at the beginning of when its just about to spin
ok, I got it back online. first the usb cable is cheaply made, I had to wiggle it and noticed you hear in connecting and disconnecting. I also uninstalled everything and re installed. I then got it back online and notice page 1 is all blank under throttle and the tq settings under it. luckily I had a pic of the original settings, so I inputted it back and saved, it spins now, thank god because one of the fault codes said controller failure when it wasn't working.
do I leave it on model em100? mine is the em150sp. and they don have that option just em150.
