luisoduran
🧲 New user
- Joined
- Jun 5, 2021
- Messages
- 4
Just solved
Goldikc said:hello everyone, I read almost all the lines but I didn't understand much , I want to put a weak current at the first speed of 30-40A and speed limit, and then everything is 100%, I bought the kit 2 years ago 3000w votol 150 sp, so can I do it or not ?
It identifies as a pl2303 usb to serial converter but there's a CAN termination chip on there too, can't make out the markings unfortunately. My guess is it "should" work with any serial port (ie, usb serial) CAN interface, might be able to check that next time I'm plugging in but that wont be for a week or so (everything stripped down at the mo).squall333 said:I bought this controller from someone on EBay and he sent me a Non-canbus cable even though it’s stamped CAN on the controller. Does anyone have info about the cab bus cable?
Don't touch the right hand values. Apparently the app is very misleading on what those values do, they don't relate in any simple way to the left hand values and instead relate to other things like waveform shape. So far there doesn't seem to be any documentation on them and they seem to vary a lot between generations of controllers. Many of the badly messed up settings in this thread may be coming from adjusting those including getting locked out of the controller and settings not registering after savingluisoduran said:Yes i used the latest but on page 2, the right boxes of Flux Weakening ánd Speed percentages are different now from the old manual, so im confused in using the new soft that i dont fully understand or the older that is clear to me but not sure if might mess the controller, do you have some clesr info on those values please?
spkeezy said:Goldikc said:hello everyone, I read almost all the lines but I didn't understand much , I want to put a weak current at the first speed of 30-40A and speed limit, and then everything is 100%, I bought the kit 2 years ago 3000w votol 150 sp, so can I do it or not ?
You have an EM-150sp? What does your usb cable look like?
