borko444 said:I'll be glad if you come back with good news about your bike.
thank you very much for your help
2)
If I choose dual voltages, the values for the three gears may be different, for example: for 1 gear the left value is 70% and the right 99% or vice versa and how it will be activated or deactivated or switched. Will the controller itself determine the low and high voltage levels and what will it be?
At first, when I bought the bike, it wasn't. Maybe after the second or third charge, I noticed that as the speed picks up, the voltage drops more than before.
Thanksborko444 said:In all cases, the output 7 of the coupling is used. Normally it is white, but purple with me.
Everything else is done by the program. If you use an ISDN speedometer, you set the program to be ISDN.
If you use a HALL speedometer, you set the program to be Hull effect.
borko444 said:Normally regeneration is connected to the brakes. It is high-level and has a green cable at the 8th output of the plug.
I do not know where it is activated and how it is set up.
do you have no regeneration function? It comes with the brake applied.
These are the settings of my engine. I don't know if the snapshot parameter below is enabled for you
borko444 said:I have no idea if poor regeneration can be excluded from the program.
But I can't figure out what you really want to do.
What does the side stand have to do with regeneration?
borko444 said:Strong regeneration is only activated by a brake, which means when 12 volts are applied at 8 pins by pressing the brake, it is activated. i dont want to use high brake. i thought low brake also activates regen
Do an experiment. Connect the controller to a computer and activate the program. Without making any changes, simply open the fourth screen of the program (DISPLAY) and manually rotate the rear wheel slowly. You should immediately receive a regeneration checkmark on the program. YES regen check mark shows
By the way, what kind of controller do you have? votol 150
Rs.Anton said:well low brake (grey black wire) is connected for regen. But when i activate it in "prorgam display" shows as side stand. this is why im confused, maybe this is why my low brake(regen does not work?
borko444 said:Rs.Anton said:well low brake (grey black wire) is connected for regen. But when i activate it in "prorgam display" shows as side stand. this is why im confused, maybe this is why my low brake(regen does not work?
It's normal to have it in the program display as a side stand.
If you want to use high regeneration to assist you in braking, you must use the high brake level to pin 8 (purple wire), when pushing the brake handle you must apply 12 volts to pin 8 (purple wire) and this will activate.
Pin 16(grey black wire) is good for tying it to a side stand that, when activated, will pin 16(grey black wire) to ground. This prevents the motor from starting when the side stand is lowered and someone rotates the throttles by accident.
Lalusonny said:good afternoon, am I new to wanting to learn about the votol controller? can anyone help me to install this program on my computer, or provide a way to install the program on my computer, because I tried to install but can not, sorry if my English is not good
