which used DH-frame for mid-drive build?
Falun, Sweden
I need advice.
Which one of these that could be realistic for a proper and safe build with the GNG 48v brushless kit?
Thanks!
Kona Stinky. 742 USD
some to fix, but easy when kit comes on.
price update after negotiating with seller: 519 USD
Kona Kahuna 445 USD
need disc brake-kit
Scott Nitrous 1113 USD
expensive?
Your pics aren't showing up, but...I recall a lot of builders using the Kona Stinky because they could fit an acceptable-size of battery in the triangle of the frame. That might be worth thinking about. If you buy one of the lesser expensive frames on your list, perhaps put some of that money towards a $130 Thudbuster. Can't improve on it for a hardtail.
edit: pics showing up now for me, I agree on the Kona Kahuna, big frame triangle.
I would go for the Kona Kahuna , and change the forks .
in the frame you should have enough space for some good batteries , 15 ah.,and the controller .
but ..... if you really want to make a nice job , cut the frame and add the battery container ecc , Scott Nitrous .
Renago
