Programming APT AE96600 controller (update: NOT recommended, unstable program)
You can just rename the file from .dat to .zip, or even just add .zip to the end of the .dat, so that the forum will accept it.
Thanks, let's see if it's usable for @jolled67
  • AE1405-110310709-T06701-100200403_a - Copy.dat.zip
Seems to have correctly attached the file (though I don't have one of these controllers to test the file by writing it).
As a content test, I opened it in a Notepad program
and these are the first few lines, if you want to match them to your source file the same way:
Code:
çL+6Ãäç=ÝAxq¸OÛ@+z¯÷,àw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°lw#ä(°l?Wiá)ǯ9XC‰EÊÛõ%ØúºrhG2޶æCÌááÎýw#ä(°l1'´ÊXù’3· l_×W#,hÁÍ!    É8䨻œ:ˆT“ù²þQœáŽSÜéSı‘ón~ îñ…G–fî&îôi¬D#ùÿ\¡Òå܈œºé)±…]ÏBà
‡ì@sŠ•—ŽÐyË\½ñªÄ¬å¤
Hi! For everyone who considers it a firmware - this is not a firmware. This is a config file that is uploading to the controller just like firmware. I have one provided by my motor manufacturer ONLY specifically for AE1405 96600
  • Firmware Updater V1.5.zip
Hi guys,
Can anyone help with the most recent APT 72400 .dat firmware file. I flashed the one that my supplier give me which was a 2020.dat file through the APT firmware upgrader and now my throttle doesnt work. I can still change settings via EV manger and they write. Any help would be really appreciated.
Thank you
Nathan
Hi guys,
Thank you
Nathan
Hi Pskin132
Could you share with us this version that you have? I am also in need of the updated original firmware.
Thanks
Hello friend, I have an apt 72400 controller like you and I am having the same problem. Could you tell me what solution you could give to the problem or if you can share the solution you had? greetings
Hello friend, this firmware only works for the 1405 controller or it also works for the 1705 72400? I ask because I have the same firmware problems but my controller is an apt 1705 72400 regards
Hi,
I have the same controller, but I need password to access for manual and software!
Do you think that the password could be same?
Thanks
Hi all, time ago I've got an APT AE2026 controller, it was OEM for Time-ET bike, and actually it doesn't work out from the box.
No I'm trying to get it work and here is an issue:
when you power on a controller - you will got blinking red 2 times and then it will just continue to glow, on the same time green light glow all the time.
See the short - video Animated GIF - Find & Share on GIPHY
Any Idea what it may mean?
I've already tried to check wires for "F" gear, "park", "brake" ect, no result
And maybe someone have a pinout for programming connector, i'd like to try to connect it co computer.
Привет, теперь есть новое программное обеспечение APT
Теперь программа прошивки встроена. Если вы подключены к Интернету, вы можете обновиться до последней версии и применить настройки в виде файлов DAT.
Приложение Bluetooth тоже работало. Сначала я купил 72420, а сейчас собираюсь купить 8055
hi do you have a username and password?
Oi, pessoal,
Alguém pode ajudar com o arquivo de firmware .dat mais recente do APT 72400. Eu atualizei o que meu fornecedor me deu, que era um arquivo 2020.dat, por meio do atualizador de firmware do APT e agora meu acelerador não funciona. Ainda posso alterar as configurações por meio do EV manger e eles escrevem. Qualquer ajuda seria muito apreciada.
Obrigado
Natã
Preciso do firmware para o apt72400. Alguém tem?
Hi guys,
Thank you
Nathan
Hello friend. Do you have the older apt72400 firmware? I have a newer one. But I want an older one.
  • APT72400.rar
Hey guys!!!!
Here is the newer software (3.0.3) also Firmware Updater.
That literally saved my buddy’s bike. We accidentally bricked it with an older version of the app and then used this one to download the configurations from mine and apply it on his. Restored it fortunately.
Now trying to get the newer app so I can set the max rpm higher
Hello, how can I access this website or application?
Now APT company's app is integrated into the Wechat app as a mini program (app within app). You just need to install the Wechat app and search for APT to run the mini program.
