Pajda
EVE 40PL sample:
EVE 40PL disassembly
BAK 45D sample:
Test setup:
- Samples was dressed into standard shrink tube with plastic isolator on the positive terminal.
- ca 5.5 mm^2 cross-section copper strips (11 mm wide with a thickness of 0.5 mm) were welded with the use of Micro-TIG welder to all three competitors (Molicel P30B, P45B and EVE 40PL)
- 6 mm^2 (power) and 0.5mm^2 (sense) Cu wires, ended witch cable lugs with M5 screw, were used for 4-Wire connection with the battery tester.
- Only EVE 40PL is shown as example.
Data Table:
20 A discharge Cycle life Tabless cells only
* 20A is limitation of my actual Neware BTS-4000 battery test system setup
Graph below shows dT = Tend - Tstart (The difference between the cell body temperature at the beginning of the discharge which is RT: 20°C with up to 3°C tolerance and the body temperature reached at the end of the discharge). As a Temperature sensor is used NEWARE T-type miniature (0.2mm) thermocouple, attached with kapton tape.
Mixed dchg-rate Cycle life Tabless design vs. Tab design
Discharge Voltage charts
tabless cells vs. Molicel tab cells
BAK 45D sample:
Test setup:
Data Table:
