ebike4healthandfitness
Power poster
- Joined
- May 19, 2012
- Messages
- 1,283
And I'm glad Bafang is working in this direction with their new automatic internal gear hubs.
Particularly impressive is their new 5 speed IGH rated at 200 Nm torque which they pair with their M620 "Ultra" mid drive.
I am assuming the next step will be to integrate that beefy 5 speed automatic IGH into the M620 "ultra" mid drive as we see numerous other companies doing with gearboxes and mid drive motors (e g. Pinion and Intradrive.... along with several others).
Bafang integrating the 5 speed automatic with the M620 will allow for dish-less wheel builds (even on frames with narrow rear spacing) and greater chain (or belt) to tire clearance.
A Dish-less wheel (at X distance between spoke flanges) is a simpler and more durable wheel.
But I don't think it should stop with Bafang.
Having a much more simplified and durable drive train is only part of the solution. Other parts of the bike also need to change as well. Perhaps Air-less tires will also be part of the solution:
electricbikereport.com
This so more people can enjoy biking without being intimidated by what they see as a overly complicated and fragile device.
Gecko Tyres Review – Puncture Proof and Sustainable
What Are Gecko Puncture Proof Tires? Having a puncture can be a total nightmare; you might find yourself stuck in unpleasant weather attempting the fix, or discover your particular type of tyre are one of those hard to get off the rim ones, or find that that you thought you had removed the...
