Yes, if you put a max485 whit twisted cable the problem disappears, but you need to implement the rs485 protocol on your mcu.I think I'm going in that direction - unless I find documentation on how Votol has programmed it's "one lin".
A MAX485 transciever close to the Votol will definently provide accurate data.
You're welcome. I have found so much knowledge here, that would have taken ages to research on my own, so sharing my own research is like a must, for me.
I use a nextion display for the graphic part, and use a PICMICRO for comunication and use it to send by serial protocol the throttle/brake/lamp etc. Like a fly by wire!
I want to use the one-lin cable to read the data and the serial connection to make any change of the controller parameter by the display!
