hello
I own stiga c300 e-ride for 1,5 year (2 seasons)
it is basic (lowest) model in line up
higher models (C500/584e/384e/798e)
it has 14S li ion (58,8V max) 30Ah battery
stock charger - 5A (FANLESS !
optional charger - fast charger 18A cost about 450-500euro :O
I can mowe 3000sq meters on one sitting 100-10% battery if I mowe regullary and grass is low, I dont mind to cut 60% of property , charge for 3-4hours and make other 40%
my MODs:
- button/remote instead stock ignition key (very annoying) (for remote I have to build small 12V li ion battery for receiver to stndby)
- added CRUISE CONTROL + ECO button (avaible in higher models only)
- added LATCHING button to cut on reverse without holding a reverse button - not avaible normally bcoz of safety reasons)
- 3d printed handle for stock charger (annoying to plug sometimes)
- voltmeter (by default its only 5 led status bar
- in higher models its app and bluetooth connection so you can see %)
Stiga made their custom charging plug/socket - but under the panel it is regular anderson powerpole 30a connector, so you can change charge port or charge with any 14S charger (in comparasion to stiga fast charger price, most expensive charger on aliexpress its GTK waterproof 14S 18A charger (similar look to surron one) cost about 180eur, lower models cost 100-120 maybe, so 450-500 is absolute ripoff)
I tested it with my adjustable voltage/amp rectifier and works fine (max i tested is 18A like stiga fast charger but breaker is 30A so maybe it can charge faster but, in my opinion 10A is more than enough (its +65% under 2hours)
ALL mods are reversable, plug and play
- I still have warranty for it
future mods to do:
4-channel remote, one to on/off, second maybe to turn on LEDs, 3 and 4 to ride forward and backwards (i know its totally unnecessary but will be fun to do it)
PS
power consumption for 2024 season - 62kWh (I cut grass very often)
PS2
voltages:
100% of charger - 5 bars - 58,8V (so really 100%)
but 1bar blinking, whe ride only is possible, no blades, its about 48V so really about 5-15%
my MODs:
future mods to do:
PS
PS2
voltages:
