ebike4healthandfitness
- Joined
- May 19, 2012
- Messages
- 1,283
As some of you know I am huge fan of buying pre-built ebikes on sale. (Pick up one on sale during winter then sell around 16 months later for a very good price. Wash. Rinse. Repeat every year to maximize your ebike experience per dollar spent)
However, sometimes I like to tinker with that idea of building something with DIY parts to see how these processes compare.
So for 2024 I suppose my ultimate DIY build would include the upcoming Grin fat bike hub with 150 x 15mm spacing for use on the front:
endless-sphere.com
This combined with the Bikee Bike lightest mid drive which promises 175mm Q factor when used with 68mm BB. (I am assuming this is the configuration that has both pedal spindles equal length from the frame center line)
lightest.bike
So now you are saying....."Woah wait a minute? You want to combine 150mm x 15mm front hub with a 68mm BB shell?" Yes and I can achieve this by using a Jones Frame and Jones fork set (or complete Jones bike) which is optimized and time tested combination using 150mm x 15mm fork, 68mm BB shell mountain frame and 148mm x 12mm thru axle rear hub:
www.jonesbikes.com
As far as rims go I would go with the Ryde Andra 29er which we have (at large) previously agreed on as the ultimate ebike rim:
www.ryde.nl
As far as batteries go something from Grin would be my first choice.
Nice! Very Nice! (Upcoming Grin 45mm Direct Drive motor)
So happy to see this one coming: https://ebikes.ca/shop/electric-bicycle-parts/motors/fat-all-axle-deposit.html I wonder what the right and left flange offset will be for 150mm front? Been wanting to see something that could make a dishless front wheel with disc brake for quite some time...
Lightest ebike kit
Lightest ebike motor is an innovative bicycle drivetrain which combines superior performance and lightweight design.
Jones Bicycles- The high performance Bicycle.
This Is the Only Bike You'll Ever Need
Andra 29 R - Ryde
The heaviest rim in our range, the Andra 29 was developed to stand loads up to 150kg.
