SammySamm
Yeah, I don't like the walk assist. Weird and jerky.
Today the Photon Gen.2 has been introduced by „CYC Photon Owners Official“.
The new motor is an inrunner, torque has rised up to 120Nm. Its slightly larger and heavier.
New here and contemplating a photon build for eMTB riding (vs OTS). I ride some technical trails and I occasionally smack the BB pretty hard on a rock. How will the photon hold up to that kind of abuse? About 2800lbs of rider + bike smacking the motor while riding over a rock?
Thanks. For me, it's pretty much guaranteed that I'm going to smack that motor sooner or later. I already smack my BB enough to know that. The question for me then is just how much of a hit can the motor take? Even if I were to go with a Stealth or X1, I'd still end up smacking them eventually. FWIW, this is almost always while climbing or doing technical traverses. I'm more careful when descending because I'm too old to keep breaking myself.If the terrain is like our rock gardens here I don't think it would fare well. The motor casing has decent clearance but still sits well below the BB, which is true for all one-piece mid drive motors. I know my dual susp MTB will compress a lot climbing over a pile of these rocks and a low hanging mid drive like Photon might take a hit. For straight eMTB you'd do better with a Stealth or X1. The motors tuck up higher along the down tube... or on some bikes can even be installed within the triangle, IIRC. They come with a pretty much standard looking separate torque sensing bottom bracket. For trails with smaller or no rocks the Photon would work great.
I had a sprag clutch fail at about 1500 miles. Note that I have always run my Photon in unrestricted race mode so pretty hard usage although I always monitored temps and kept them at or below 90C Supposedly a firmware update made the startup softer so that might make it better.Spragg Clutch issues?
Hi, have many people here had Spragg clutch issues on the Photon? CYC make a big deal about the fact that they upgraded the clutch from 12x20 to 20x28, tripling the torque rating for the Photon Gen 2.
Can anyone confirm for example that their clutch needed replacement due to failure during use (rather than being defective OOTB)? If I'm re-greasing the motor at 3,000km, should I replace the clutch as a matter of course? Mine seems fine ATM.
Does anyone have photos or a spec for the clutch - is it a standard OTS part like most bearings, is it sealed (or should the replacement be sealed) and does it have keyways? Any markings?
Good videos on youtube on disassembly by CYC and johhny nerdout.
Make sure you note the exact orientation of the sprag clutch when removed as it is a one way bearing.
It comes with grease as well
There are actually two sprag clutches.No problems with sprag clutch here even though I also run unrestricted race mode. Interesting that CYC tout how the Gen 2 will be easier for maintenance when the Gen 1 really is pretty good that way already. I guess pulling that glued on cover on Gen 1 to swap the controller could be a bit of a PITA but the sprag and torque sensor are right there after you pull the chainring.
Thanks, I run mine very conservatively generally at low assist but up to about 750W on steep climbs in low gear, never really gets hot. I think my primary clutch will probably last OK but there must be a widespread problem for CYC to address this with the new version. Maybe it is just people running the motor a bit harder.I had a sprag clutch fail at about 1500 miles. Note that I have always run my Photon in unrestricted race mode so pretty hard usage although I always monitored temps and kept them at or below 90C Supposedly a firmware update made the startup softer so that might make it better.
That's the wrong clutch, but as a matter of interest, the 2nd stage clutch shown in the video is different to the one shown as spare parts on CYC website. Video shows just a caged bearing, the website shows races as well. What does yours look like?No problems with sprag clutch here even though I also run unrestricted race mode. Interesting that CYC tout how the Gen 2 will be easier for maintenance when the Gen 1 really is pretty good that way already. I guess pulling that glued on cover on Gen 1 to swap the controller could be a bit of a PITA but the sprag and torque sensor are right there after you pull the chainring.
Heh, my old Stumpy is a 2014 EVOOn my old Stumpy
I dont remember seeing any 'obvious wear' on parts other than the sprag clutch. Nothing stands out in my memory on the actual sprag clutch either but I am by no means qualified to make any judgements.What actually fails - is there any noticeable wear on the shaft or the gear it fits in, or is it due to damage on the rollers themselves?
Heh, my old Stumpy is a 2014 EVO![]()
I paid NZ$150![]()
for it because it was derelict and had not been ridden for years - turned it into the best bike I own. That model was the earliest of the modern MTB geometry trends, is lightweight and easy rolling, a delight to ride. Not getting a conversion though, no way, it is just too good for that.
Thanks, that is really helpful - seems like we should get plenty of warning a=so best to be aware and intervene before any real damage is caused.The initial behavior was that of stuttering on startup from a complete stop. It felt alot like a motor controller which isnt setup right causing the motor to stutter on initial startup. It only happened in the highest assist level and moreso when it was colder. Im guessing this was the sprag clutch slipping. Finally one day it got really bad, I could hear the motor spinning but the motor would not engage. I could get the bike going but it was a crapshoot every time I started or even when applying power after coasting.
...but as a matter of interest, the 2nd stage clutch shown in the video is different to the one shown as spare parts on CYC website. Video shows just a caged bearing, the website shows races as well. What does yours look like?
Some progress since my previous post. Spragg clutch seems fine - well greased and clean, no sign of any contamination.Photon failing at 3000km :-(
CYC Photon motor from one of the earliest production runs with 3000km use over just under 3 years is becoming noisy and exhibiting a very concerning issue. Bike rides and performs normally at this stage. I would probably not have noticed the wear without inspecting the motor with the chain removed. Motor hasn't been subjected to extended high power use and has generally been used in good weather.
The drag between crank and chainring varies depending on the crank position relative to the motor. This can be felt when operating the chainring by hand, but becomes very obvious when under throttle power. The motor has done this from new, but was barely perceptible initially. It was generally not noticeable in normal use, but is now becoming more evident, and also noisy.
With the chain removed and rotating the chainring by hand, the bearing sounds and feels noisy. I suspect there is an underlying manufacturing problem that was not identified before shipping that has caused this failure over time.
Appreciate any similar experiences from others here, or who have replaced the output spragg clutch.
*I mis-spoke in the video: the chainring of course rotates relative to the crank, but only under throttle power, I was referring to rotating it by hand which is of course a scenario that never occurs in use due to the rear wheel freewheel. When riding without throttle the chainring and crank relationship doesn't change.
I've added another video with no commentary, the mic here is a DJI Mic Mini placed on the bike frame to more accurately record the motor noise. IRL the motor is not this loud.
Further update after disassembling the motor. Generally the motor is clean inside, no sign of water ingress, with plenty of grease but I would still recommend cleaning and repacking at this mileage. CYC have used a very nice waxy white grease which is brilliant - because it shows any wear and metal contamination very clearly. I would consider there to be normal amounts of metal contamination on the gears at this stage.Some progress since my previous post. Spragg clutch seems fine - well greased and clean, no sign of any contamination.
Removing the chainring was a nightmare - had to use the CYC tool, held firmly in place with a 12mm coachbolt and spacers through the BB. Then soaked the ring with CRC for a few hours, and used 2x 1m lengths of 2" and 1" water pipe to extend the leverage on the tools. I was surprised the CYC tool didn't fail. I had more trouble with the chain whip folding.
The larger output bearing appears to be the problem - it seems dry and noisy but apart from minimal dirt on the seal doesn't seem particularly contaminated. What is the size of the bearing (is it 6816-2rs?) and how is it removed and replaced?
I get (as close as I can measure) 80mm x 100mm but can't measure the width with the bearing in place.
Can the output gear and bearing be pulled out using the chainring retaining ring? I've removed the bearing retaining ring, but nothing seems to want to come out.
Any help here?
