patracy
๐ New-ish
Since it's vesc based, do you have a github where you're sharing the firmware for your device?
Weโre building on the VESC firmware ecosystem with our own hardware configuration, tuning profiles, and platform-specific integration work.Since it's vesc based, do you have a github where you're sharing the firmware for your device?
Fair question, and I understand why you are asking.VESC is open source, that's why I was asking about your firmware.
Seeing this is still in the R&D phase, I assume you've not yet implemented one of these higher capacity controllers in a situation with a encoder as well as subjecting a motor to say 30kw?
Fair point.Do you have a individual that is actively using one of these higher capacity controllers that might provide a customer sided reivew?
Hello Shadowsabre. Do you want to start making this 12FET High Power Controller for Bafang M620? It looks like there is a lot of people who would like to have itHi everyone,
Iโve been working on a high-power motor controller focused on sustained load performance rather than just peak specs.
endless-sphere.com
I highly recommend adding a redirect on your old website so people don't think you went out of business if they go back to itQuick brand update: Our high-performance motor controller product line, previously introduced as Shadow Sabre, is now called Symbyote Systems.
Thank you for your suggestion, we have already done it. We will check again if it is not working yet.I highly recommend adding a redirect on your old website so people don't think you went out of business if they go back to it![]()
