TPEHAK
Regular
Prepared the rotary encoder. If you want to use the same rotary encoder you need to solder a 1 kOhm 0603 resistor (0402 fits too) to the R3 soldering pads.
26 AWG silicone wires can be used to connect it with the BRAIN board
Since the bottom face of the encoder will lay on the flat face the soldered wires should not stay above the surface
