I managed to not run over my feet, whcih is good.
The headlight worked beautifully, and I can actually DETAIL on the road in the spot, about 3 carlengths in front of me, and still see the area between the spot and me, plus some beyond it. The sidelighting of the spot clearly lights up the road's full width plus sidewalks, on typical non-major roads. On major roads with multiple lanes per side, I can see the full lane I'm in plus some on either side.
Only downside is it's still halogen, still incandescent, so it's using 50W of power for all that light, where I'm sure an LED version would be a tenth of that. But the other smaller lighter halogen was also 50W, for a lot less useful lighting (was a big cone of light).
Weight distribution isn't bad, but it does feel different both when slowing down and when turning. Pretty sure all this weight that far back is harder on the rear tire, which almost feels wallowy even at the higher pressure Iv'e got it at now (about 65psi). I'm afraid to inflate this cheap thing any higher with this weight on it; the tube or stem will probably blow.
The Volgood pack seems to be working ok, but it seems to sag more at a lower current load than the Vpower pack does. It also starts off at least a volt lower than the Vpower pack. I'm not sure if regen is actually less with it or not, but it feels like it.
