Lurkin
Data logging and ability to upload it to a PC. Don't care if it's a seperate unit to plug in (like the CA analogger) or part of the adaptto, just would like the functionality available.
Offroader said:Another feature that would be nice is to be able to select throttle voltage or cruise speed through the controller. This way in case of a throttle failure you can drive the bike home.
I've had to push my 130lbs ebike home a few miles already after my throttle gave out and it wasn't fun.
ccmdr said:Maybe an option to ditch the display and have a purely bluetooth/usb phone app based controller incorperating GPS mapping, dash cam, gyroscopic levels and then all the normal functions the display currently has etc... You generally get a phone with a screen size relevant to how blind you are so font generally wouldn't be an issue .
Also, maybe making the phone display app hot swapable so you can switch between your commuting and offroad bike, so you could also monitor charge/charging staus when the bikes are in the garage. Allow buddy tracking with GPS for the odd woods runs when you get seperated, flat tyre's, breakdowns etc... Also so you know when to put the tea on for your partners return :wink:.
Wireless phone charging if bluetooth connection or wired DC-DC charging if USB connection. App using google maps (or equivalent) topographic elevation to automatically adjust/predict amps for max speed or range required for a more accurate 'Set Range' function. Why have a 10/15/20/30 ah size pack and use 50-60% when you could have more fun going faster or maintaining speed up hills and go to the full 80% DOD or relevant user setting.
More accurate 'Power Mode Profiles', if max power is set to 20A for example, I mean 20A not 22-25! Yes its a bike but a heavy one especially single speed, up hills in the rain :lol:.
+1 like cycleanalystdrew12345 said:I would like wires coming out bottom instead of side so not so visible.
Edit: a different mounting system. Right now, you can only mount on handlebars. Make it so you can mount on handlebar or flat surface like ebike frame or stem.
Mammalian04 said:This exists already as a special firmware. Email Adaptto.
ziltoid81 said:We in europe need a "cop mode" badly.
Something to lock the eco profile in fast and you wont be able to change it into the other modes, unless you have the password.
The best solution would be an upgrade via firmware, so the customers dont need to buy a new controller.
I would spend money if there was such new firmware......
Maybe a special firmware where one existing button is for locking the eco mode in fast.
For example the exit key in normal or boost mode. Hit it once, it will lock in the eco mode.
All other customers can use the normal firmware, if they dont need this.
drew12345 said:Please add OVS feature to quick setup menu.
