brumbrum said:
Abneycat said:
Hello! I've been working on a Lightning Rods + Adaptto Mini project and could use some advice.
After modifying some settings, the autodetect process worked perfectly from what I can tell. It was smooth and spun up to speed properly at the end stage.
The problem is that after exiting auto detect and being in ride mode, the system is still smooth and starts properly but seems to be severely limited in power output. The motor will not spin more than maybe 25% of max speed, with a power drain of around 100W.
If anyone knows what settings may affect this or has any input, I would sincerely appreciate it.
Have you adjusted the setting in your profile window in the main display menu? Eco, normal, boost settings. This Would be the thing to check first. Apologies if i have stated the blatantly obvious.
I had adjusted the assist levels, yes. Thank you for the suggestion.
I eventually got this working 100% last night. I don't know what I missed the first time, but performing a reset and then changing the settings that helped get to that state before resulted in a fully working system.
This was my process to get the Adaptto Mini-E to work with the Lightning Rods Big Block:
1. Default wiring as per Adaptto instructions
2. Update firmware on Adaptto
3. System reset through advanced options immediately after update
4. Changed hallreverse and rotation options to get over motor not initiating autodetect properly
5. Adjusted timing to make system run smoother
6. Changed assist level settings to work well with LR big block
That seems to be all it took. I'm going to do some more fine tuning, but it's all working properly now.
This controller is super cool. It's awesome how it has built in diagnostics that are easy to use, and a huge plethora of customization.
I wanted to ask about the Wire R PHC option. I tried using this and it really smooths out the response of the motor at the low end, but it also seems to affect the response of the throttle as well. In particular, when the throttle is just barely pressed, the motor isn't moving but I see a drain of around 10-20W and can hear a faint pitch noise coming out of the motor.
Should I be concerned about that? I'm interested in using this mode due to how much it improves the initial smoothness of the start and low speed.
