Jonboy said:Hey guys anybody got a fix for this.. My Max E has been working fine but just recently when I switch it on instead of the normal ECO-BMS-ECO on start up it displays PROTECT-BMS-PROTECT... Disconnect from the battery then reconnect, then it's perfect.. ECO-BMS-ECO. rides normal no probs![]()
Very annoying, I really don't want to damage it at the mo as my lad gets his adaptto/raptor setup for xmas.. I'll be gutted if my bike is in dock & we can't go ride together!
chucho said:I would like to use a conector like this
To use the eaton 1800w to charge. What other options are you ussing?
I saw some time ago a cover that was posted here for this conector so no water could get inside but cant find it any more![]()
Mammalian04 said:chucho said:I would like to use a conector like this
Hi Chucho, I would purchase the 8 pole version so you have the versatility of paralleling poles if you run more amps later on. Easier to start that way.
Regarding the covers, be careful about which covers you purchase. I have not found a cover that works with the slightly larger sockets that have 4 screw holes. I bought the wrong ones (for the lighter weight versions with 2 diagonal screw holes) and these gaskets and plugs are too small. I haven't found a plug cover that fits and keeps water out yet.
If you DO end up getting the smaller 2 hole version (smaller hole to cut in the bike frame), I can send you some gaskets for free as I will never use them and it is too late for me to return.
EDIT: Nevermind, I see you are in Spain Chucho. Cheaper for you to purchase locally. However, if there is anyone in the U.S. that wants the Neutrik gaskets, I have a bunch that they can have for free but I still recommend using the heavier duty plugs and just make cut your own gaskets.
ccmdr said:Using this XLR with dust cover for my Eltek flatpack @ 53.7v 30A (37A available). Tighened the spring on the back and I've yet to get water ingress, with 'sunny' UK weather :wink:.
ridethelightning said:thats a neat looking cover. id not seen it before.
so will it fith the nlt4fx type sockets?
i have used the 40A version for charge socket, I was a little hasty to get the plug soldered up and made a pretty crap job of it, as i needed to show the bike to a potential customer in 15mins :lol:
I think it may be cause the solder joints were done in a hurry, but the plug was around 55-60C (Hot to touch) after charging at ~30A psu current for 15mins.
Seven said:It all depends on what socket you are using, NLT4FX is a plug, what sockets are you using on your bikes, that cover will fit quite a few sockets that will accept the NLT4FX but it depends on which one you've installed
ridethelightning said:with those lower rated 30Acont sockets, what temps do you get charging at ~30A psu current?
just trying to find out if mine gets hot cause of the bad solder joints or if the socket is over-rated...
Mammalian04 said:ridethelightning said:with those lower rated 30Acont sockets, what temps do you get charging at ~30A psu current?
Others have noted that the sockets are overrated. That is why I paralleled mine on the 8 port.
KiwiEV did an awesome cooling mod to his controller using a CPU cooler mounted under the seat sub-frame:ridethelightning said:the other possibilty is attaching copper heat sinks to the controller, and running thick copper cables off that to the outside air, with sinks on them....or do both
has anyone had sucess with using fans with in-frame controllers? what airflow is needed?
