Animalector
Wiring is almost done. Have anti spark connector wired to the 100A breaker and the charging connector (via a 30amp fuse). Then To a massive 150a Anderson for connection to controller. Pre charge button wired across the circuit breaker. Using 1k, 5watt resistor.
All that is left is the Anderson onto the controller leads then test.
