Banshee Chaparral with GNG gen 1.1
arcticfly said:
I might be able to squeece 3 zippy flightmax 6s 5000mah. in the triangle, 6 if I put 2 beside each other. that is 10 cm. Since yours is 12cm wide, dont you think it is too wide?
Nice frame! Diffrence is that i have a xl and yours is a m.
I think that you can fit 18s2p in your frame.
Make a mould of your frame with hardboard and then fit the lipo's
You will see it will fit. 12cm is like a sort of standard. Bomber is the same.
Then you have some space for your wiring
arcticfly said:
I have made a mockup and it is so tight, but it might work with 18s. What kind of speeds do you get with 18s? What amps are you using. Could you me what speeds you got with 12s 50 A?
Cheers
Alex
I get 70kmh with 18s. I run it on 50a and sometimes on 60a. I have a lyen 12fet.
With a 9fet i think 40a is the max
12s will do 55/60kmh
For a gng is amps very important. The gng uses the gears of the bike so max rpm from the engine is not to compare with a hub. With the wright gear and amps you can get a higher speed than with a hub on the same volts.
arcticfly said:
Is your pedals useful at 18S with the reduction you have now? Or is it just a foot rest? And why just the upper sheets from LS?
With the uppersheets you can make adjustments in the chain drives. So you can tighten or loosen the tenstion.
You don't need the idlers anymore. Yes pedaling at lower speeds is usefull but on high speeds the cadans is to high.
I use my bike for offroad. I pedal a lot
