spaceman
This device is pedal assist only. I may think about a different device for throttle only usage, but not now.1. The option of using throttle only.
2. Cruise control
2. Cruise control
Correct.I'm told it will throttle down when the heat is too high..
Frame of the device, not the bicycle.There is a thermal path from the motor and electronics to the frame of the device to dump the heat. Apologies if I wasn't clear enough.the bike frame becomes part of the thermal mass to dissipate motor power.
Please see the answer above.The coupling to the frame seems pretty minimal.
I have no definitive answer for each and every cassette, sorry.So, is it two gears or three gears, to be specific let's say on a Shimano 11 speed 105 cassette?
Aram, I sent you a more detailed inquiry about clearances and the 'motor mounting plate' thickness via email. Easiest would be if you published a few cross sectional drawings or sketches, so I (and other potential customers) can figure out the fit and cassette reconfiguration options. If you are worried about copycats, you could publish a 'stay clear' outline.There is no way (at least yet) to keep using the largest cogs with this device. You still can use and shift the smaller ones though.
Yes, I received it, will reply shortly.Aram, I sent you a more detailed inquiry about clearances and the 'motor mounting plate' thickness via email.
I'm told it will throttle down when the heat is too high.. and also, the bike frame becomes part of the thermal mass to dissipate motor power.
And yes, you lose 2-3 gears, depending on the cassette.
I was just posting this for the guy who wanted the throttle only function, which IMO would not be wise on a motor this small.
@raylo32, I think this is because the BikeOn design drives off of the (hopefully 25-36T, via sized rotors) inner cog/sprocket, and the narrower your cog/sprocket spacing (worse with more speeds) my guess is more cogs/sprockets are blocked by the design and not usable (and related to limiting the derailleur span).What does this mean and why doers this happen?
@raylo32, I think this is because the BikeOn design drives off of the (hopefully 25-36T, via sized rotors) inner cog/sprocket, and the narrower your cog/sprocket spacing (worse with more speeds) my guess is more cogs/sprockets are blocked by the design and not usable (and related to limit the derailleur span).
Shades of compensating for the BBSHD chain line woes, rearranging the sprockets/cogs has been mentioned.
My best guess..
You use the tallest gear in the stack but some derailleurs might smack the drive ring, so that's why the number of gears you lose is variable... depends on your cassette width/type and the shape of your derailleur.
If you don't have huge hills, you will only need a few gears with this amount of power.
I'm looking into that for my potential application. My current thinking is that restacking might work if I switch to an 11-to-32 teeth 11speed cassette; but that leaves the question you brought up, namely how usable is this bike then without the motor?That pretty much defeats the purpose of being able to slap it on, say, my gravel bike with 11-speed Shimano for a ride and then take it off... I mean if I have to restack the cassette. I wonder what cassette is "ideal" for it?
Chain always passes below that bearing marked on the picture.One question I can't answer from looking at the pictures is: can the chain run over the roller near the top, or is that just a bearing for the red ring, and the chain has to stay clear of it? If the chain is allowed to touch and partially wrap around that roller (green line), the largest possible driven cog diameter that clears that roller is about 135 mm or about 33 teeth; if the chain has to stay clear of that roller (blue line), the largest allowed driven cog diameter is about 104 mm or 26 teeth.
I don't know where you are taking these numbers from, but the device accommodates 36 teeth sprocket with no problem, tested.the largest possible driven cog diameter that clears that roller is about 135 mm or about 33 teeth; if the chain has to stay clear of that roller (blue line), the largest allowed driven cog diameter is about 124 mm or 30 teeth.
What are you trying to solve? I am a bit lost here...My current thinking is that restacking might work if I switch to an 11-to-32 teeth 11speed cassette
Guys, i continue to be on the fence about buying this motor. I don't really have a strong application for it RN, moreso curiousity about this novel drive mechanism, and a want to support innovative companies ( we need them.).
I've PMed spaceman back and forth, and he is an intelligent, no BS, and very helpful dude.
If you are looking at a 500-750w geared motor and want PAS, then this would be a great alternative to that and blow the power/weight ratio of any geared motor out of the water, even my beloved Shengyi SX2.
For cassettes, i would run the highest gear count that fits your wheel. You got 7 speed? use a 9 speed cassette and dial out the last 2 gears - now you have a 6 or 7 speed.
@blinthor, per the BikeOn site FAQ: "BikeOn is designed to be compatible with most standard bicycles with gear size of between 25 and 36 teeth. Currently BikeOn is not compatible with BMX and other single gear bicycles (fixies), Brompton and other folding bicycles, bicycles with belt drives, internal gear hubs and bicycles with a chain guard."Hi
I have two questions.
1. Is it possible to work with a belt drive?
2. What about Shimano Alfine or Rohloff?
Hi @raylo32 - I think @spaceman responded early on that the drive safely blocks the derailleur, as you surmised - I can't find the particular post though.I totally agree. Spaceman does a great job responding but some of these questions can't be fully answered until we try one. My potential use case would be a 2x gravel bike with 11-speed cassette with 32t biggest cog. Especially for travel so I could take 1 bike and have an analog bike and an e-bike in one. Damn.
And I would have to be able to pop the device on and off with no other mechanical changes since I ride this bike analog a lot. I don't even want to have to run the rear derailleur mechanical stop in to keep it from going too far. So, I'd have to be careful shifting... or maybe the device drive ring would just block it if you tried? Again, have to try one to know.
Since the small chainring is 30t I would have plenty low gearing even losing the top 2 (or 3?). The 30t even with only a 25 cog is still lower than my other e-bikes that have 32t cogs and 42t chainings and they easily climb everything I need to climb... and I never even use the 32t cogs on those anyway.
