Rodney64
Kim if I get a Kelly controller can you help us wire it up.
AussieJester said:EDiT Nearly forgot, i wanted to ask if you think a belt could replace the #25 chain on my bike? I think the lil #25 looks too whimpy compared to the rest of the components...thoughts?
Thud said:RE Belt drive.
It will work & there isn't a huge reduction IIRC, Your running (17-32)???
The only issue will be bordering the torque limits on the belts...wider will fix that though.
Belt wrap is the key to good performance. I would start with a 21-40 or better yet a 23-44 at least 15mm wide...20mm if you can find it.
Danny M. Is better versed in the math on the drive belt application. Lets have him chime in on it.
toolman2 said:'fat man jumps mountain bike'
Willow said:...might have to get one of those myself. for $48 can't go wrong.
Make your first video something along the lines of this - http://vimeo.com/68761077 but with bikes.
Thud said:Danny M. Is better versed in the math on the drive belt application. Lets have him chime in on it.
Danny Mayes said:Thud said:Danny M. Is better versed in the math on the drive belt application. Lets have him chime in on it.
I am using the old trapezoid profile because it is waaay cheaper and a more forgiving profile for casting my rear sprocket.
For high powered primary reductions I think Matt is the authority here.
If you want to go with the trapezoid profile i an run some calcs and make a recommendation... Upsettingly Inventor doesn't have newer profiles for playing withAt best i think it has HTD which are better suited to higher speed but i havent looked into what they cost...
This is where i got my T10 pulleys from http://shop.polybelt.com/Metric-Pitch-Pulleys_c68.htm
D
Tinto said:Kim, how do you find the half link chain for retaining tension? Reliable, stretchy, noisy?
What is the method for joining / breaking those - standard pins or something else?
I'm using 9 speed chains at the moment but its a royal pain in the ass to get consistent tension, even with a basic tensioner on the rear.
I feel like I'm a few mm out from having perfect tension which has lead me to look at a half link BMX chain.
They seem to have massive load capacities compared to 9 speed chains.
