Back in "3.2 Operating Modes: Normal vs Legacy" on page 12 the chart shows you that legacy mode is going to run like a V2 and does not provide any of the enhanced throttle features that address your 'twitchy' throttle problem. IMHO you should be using the V3 in normal mode which would be choice 'B' on page 15. Crippling it to run in V2 mode is seldom a good idea and particularly in this case where the features you lose are the features you need. (The normal vs legacy mode comparison chart is actually reproduced on the previous page of this thread.)johnnyz said:YES my Crystalyte Controller is fully compatable with the CAv3 which would qualify it as D) v2 legacy Mode operation.
As described in "2.4.2 Navigating / Editing Setup Parameter Screens" on page 10:johnnyz said:I set ThrI>cntrmode=passthru (no explanation on what this means, I am assuming it gives CA control of certain parameters of the throttle).
Extremely UN intuitive. In order to follow the instructions without confusion the writer cannot possibly assume the reader knows nothing about any of this, making a go of even following these instructions difficult.
Grin Tech CA V3 Page said:Cntrl Mode: Allows you to select the function of the users input throttle
- Pass-Thru: User throttle is linearly remapped from the input throttle range to the output throttle range, and then passed on to the output.
Since you had decided to set up for legacy mode, the section "1.EITHER – for 'Normal' Operation (CA Provides Throttle)" on page 25 does not apply and could not work.johnnyz said:got to page 25 in an attempt to map out the throttle range from 0-3+ volts and nothing happens...
and then got into the Setup Throt In screen and watched as I twisted the throttle and got 0.01 v and some flickering and thats it.
I have already indicated the audience for which the Guide was written (not a 'lay person' at all) and recommended that you pursue personal assistance from Grin Tech. It's been your choice to continue to try use a document that you find seriously and obviously deficient.johnnyz said:By the way, without FACTS, blindly following a "guide" without KNOWING exactly how something works or why it doesnt, inevitably will lead to a situation in which in this example( the writer of the manual) doesnt include most possible scenarios, or an explanation as to the particular working of each function, to getting "stuck" and then choosing a best guess or possibility based on the limited information available.
The request above in (A) to make sure the controller and motor worked was to ensure your restoration to the original wiring and connection was successful. The question in (D) as to whether the motor ran after step 1(f) was to get the critical result of the test - the whole point of the exercise. Whether the motor ran originally has no bearing on following the steps in the Guide...johnnyz said:I already said the motor was running..
Never mind. I poked around, changed some numbers and got it going the way I like it.Ecyclist said:Hi guys,
I have a GNG 1500W mid drive kit on my bike and I hooked up CA3 to enhance throttle operation. Can you post settings for CA3 running a GNG motor or a small block motor so I have some kind of starting point? Should I upgrade to the newest firmware or do it later? I still have a steep learning curve ahead of me and I'm hoping for a small shortcut.
Thank you.
Ya - I ran into exactly the same issue with Dashware some years back - when it wasn't free and didn't even have a version number...Fastolfe said:...would it be possible for the CA to output a timestamp field for each line sent to the serial port? You know, just a variable that increments in 0.2 second steps at every line, with "t" as a field name or something. That way, I wouldn't have to run my Analogger files through a script to add the timestamps for use in Dashware.
Fastolfe said:...the Cycle Analyst stops displaying the speed (it drops to 0) and stops updating the distance below 3 kph or so. I'm not sure if the speed limit is hard-coded or if it's because the time between magnet pickup ticks becomes too long. In other words, I don't know if adding a magnet to the wheel would lower the limit - I haven't tried - but it'd be nice if the limit could be lowered in the firmware without adding another magnet. I very often grind uphill at speeds under 3 kph![]()
teklektik said:The present record length is getting close to the transmission limit at the present baud rate (there are bench applications for the CA that use a record rep rate higher than 5hz). In fact, if you look at the log records in the latest 3.1 beta firmware, you'll see that we have actually trimed some needless precision from select columns to shorten the record length.
teklektik said:Actually, adding another magnet would not lower that limit - it's related to fixed timing to suppress spurious signals from the wheel pickup. Additional magnets make the speed update more quickly above that limit, but the related noise suppression interval changes proportionately with pole count so the lowest speed remains essentially unchanged. For most, this speed is not a problem, but it looks like you are one of the few that are affected by the speedo implementation. I do take your point and I'll add it to the 'would be nice' list, but my knee-jerk reaction is that it's more in danger of falling off the list than moving up.![]()
Ya - the flashing CA screen is usually an indicator of shorting the CA +5V to Gnd. In this case, I think you probably have the Analog PAS connector pinout mismatched with the CA throttle input. The proper throttle pinout appears in a couple of places in the Guide.irq said:and here starts the problem... my controller of choice is a infieon (PCB date 2016) with 12 Fet. after connecting the analog pas to throttle input, the lcd screen starts flickering, off on off on and so on. like i shortend something?
PMed.izeman said:teklektik: just c&p and pm the text you're interested, and i'll translate it for you. no need to ask google for some bs translation![]()
Yep, it could. This is discussed in "5.10 Powering Accessories with the CA" of the Guide. You can check the table to see how much capacity the CA has at your particular battery voltage. An easy hack is to run the 5V accessory (analog PAS unit in this case) off the controller 5V pin of the controller throttle connector.irq said:could the pas sensor "overload" the 5v provided by the throttle input of the CA? Whould it be worth to try with some kind of external power for the sonsor, a simple 8705 dc regulator or somewhere i should have a spare lm2596hv module.
btw, if translation is needed. feel free to tell what, i am also happy to help with
I might suggest that you use the pot for the PAS level instead if you go with a scheme without the external PAS unit. This at least gives you some on-the-fly assist control. IMO AutoPAS is not too attractive when there is no direct adjustment control. (see below)irq said:i also got a poti mounted, currently set to controll max amp setting.
Understood. Some thoughts:irq said:what i tried to do is:
(stolen from the german pedelec forums, didnt ask for permission. judge me (not))
its called pseudo torque mode there, setup looks like this:
What do i want to do? a more natural pedaling feeling, several ppl report good sucess with this.
- mount / connect a 2nd pas sensor, but a analog v5 and hook it up to the throttle input. than set the pas to something like 100w max, because the v5 should kick in at some point
- v5 is directly wired to throttle input, no other changes are done
regarding them, settings should be like
- - Autopas with max of ~100W
- - Additional SEttings for Autopas to handle the swithover
Grin has done some work with this, both in the off-the-shelf form with a throttle-voltage-range output and using a stripped version with just a torque sensor output. Either work well with the V3.scrambler said:Did you ever try the BEAMts torque sensor?
