speedmd
They solved the spoke issue a half century ago. Key hole the spoke holes worst case. If your cutting standard extrusions for cooling fins, you could notch the fins also at the spoke locations to allow spoke access.
bowlofsalad said:macribs said:Placing heat sinks in between the flanges of the motor should be an easy mod that most people can do on their own, as it does not require any special tooling. A good adhesive and you should be golden. The heat sinks would be pretty well sheltered between the flanges and with ferro fluid inside the hub as well it should make for a significant cooler motor even hard pressed in hot weather.
Get a round object and place a flat object against it, like a bottle or a jar on a counter top. This is just like placing flat heatsinks upon the rounded surface that is between the flanges, the surface contact would be poor. As much contact as possible is important for thermal pathway, but perhaps this is an issue of least importance on your suggestion.
"Good adhesive" Is also a very broad and important topic, which adhesive is used and it's thermal properties are both important topics, not any old glue or epoxy will do. The heatsinks will be under lots of centrifugal force as the wheel spins, might be a bad time if a few heatsinks happen to come off. Good adhesion for adhesives usually requires very well cleaned, paintless surfaces, not super simple and will surely be at least mildly involved. In addition, what do you do with the wheel if you break a spoke? The heatsinks would block the spoke head paths. The problem with this whole adhesion approach is that in order to do it effectively you'd probably need to start with an unspoked hub, but once the heatsinks were in place how would you lace the hub? Really huge flange with high spoke hole drillings and low profile heatsinks? Straight pull spokes?
These have been some of the engineering problems I have tried to find solutions to for the past few years. The conclusion I came to was that rounde bottom heatsinks could be put in place followed by a large hose clamp to keep it all in place. The design that I've been most interested start off with two hose clamps (one placed at the edge of each hub flange) and a sort of plastic wind scoop that goes over the heatsink/hose clamp object. The hose clamps would slide into the wind scoop object. Part of the goal in it's design that I had in mind was to paint the hub black, the heatinks, and the wind scoop itself, the reason being that it would hopefully mask the absurd aesthetic appearance that would otherwise be very easy to spot. I've imagined several different ways of installing the heatsinks with the round hose clamp. So far my favorite approach is to use thermal tape on the bottom of the heatsinks so you can enhance thermal pathway and keep the heatsinks in place while you put the hose clamp thing on. Naturally, something to consider, is that all this would be fairly costly and increase the weight of the motor.
I am sure there is a lot of expansive exploration to do on this ferrofluid subject as well as a vented hub motor, but I think that if were going to compare apples to apples, a vented motor with some version of a external fan blade would be worth comparing to finned oil/ferrofluid motor.
A ferrofluid (from the Latin ferrum, meaning iron) is a liquid which becomes strongly polarised in the presence of a magnetic field. It is a colloidal mixture comprising extremely small magnetic particles suspended in a synthetic oil. The particles are coated with a a soap or detergent to prevent them from clumping together.
Kodin said:There's also some really nice global-shutter machine vision cameras out there that can do high speed, and you don't get those terrible tearing and warping artifacts from high speed movement across the frame.
justin_le said:Next up I'll want to do the reverse, rather than overfilling the air gap and letting it leak we'll keep adding say 1-2mL at a time and then measuring the thermal transfer coefficient, and find out at what point you get diminishing or no returns.
flathill said:also note the viscosity lowers as the fluid warms up. there is another "loosening" effect that is not temp related (less particles clumping) after being "worked"
make sure to do the drag test on a "cold" motor as-found after a fresh fill and then repeat the test after the fluid has been worked/warmed
macribs said:Maybe you can do another run with sealant on the side covers to see if the ferro fluid is forced outside the hub via axle/wires/bearings?
I think it has been mentioned once or twice that oil filled hub will create internal pressure inside motor that will keep pushing fluid outside the motor - I wonder if the same goes for ferro fluid or will the magnets keep oil in place so much that leaking is not a problem with proper sealed side covers?
justin_le said:We'll also do a test with conventional ATF oil fill which splashes on the copper windings.
Coming up!justin_le said:And finally we'll try to pot the stator in a thermally conductive resin and see how well that improves the ferrofluid approach by better coupling the windings to the iron stator.
On track!Expect all this to take a couple months.
Nathan said:Would you be able to repeat these tests on an inrunner motor and see if their is any gains also ?
justin_le said:Nathan said:Would you be able to repeat these tests on an inrunner motor and see if their is any gains also ?
Nope
macribs said:Amazing work Justin. Tons of kudos and mucho respecto.
From what I can see in your tests over heating is now a thing in the past. No need to drill holes or to add heat sinks.
FF seems like a Simple, well working and clean solution for everyone, should there be any reasons not to use Ferro Fluid?
So who will jump into this and sell pre loaded syringes with high quality Ferro Fluid? If all that is needed is 5+ ml there should be possible to make a buck or two selling small quantities FF in pre loaded syringes.
Kodin said:Justin, if you have the facilities to, please confirm whether the potting affects KV and inductance of the motor. I'd expect that most thermal epoxies affect inductance, capacitance, and/or magnetic flux behavior... It'd be nice to know real-world info.
flathill said:. I'm thinking mostly about your custom motor with large magnet spacing. FF may be too costly to add unless you fill the gaps by potting the magnets also, but then you need some gaps for the fasteners....so you would have to pot with dummy fasteners in place so u form thru holes.
