macribs
- Joined
- Jul 22, 2014
- Messages
- 3,702
speedmd said:Serious increase in motor robustness with just a few drops of substance.![]()
Just like most of the famous athletes does with their magic needles
macribs said:speedmd said:Serious increase in motor robustness with just a few drops of substance.![]()
Just like most of the famous athletes does with their magic needles![]()
adding fins will do very little for cooling while driving, but possibly a bigger impact when the motor is sitting. But how much of an impact will it have while sitting with little airflow with fins should be tested.
Offroader said:I think what someone needs to do is mount a wireless thermistor to the outside of the motor case to see how hot it is getting while moving.
I know that my cromotor case gets super hot to the touch if I stop driving, but as soon as I start moving even a small amount at low speeds the hub motor is shockingly cool to the touch.
You can easily test this by letting the motor get really hot to the touch by letting it sit, then drive for just 10 or 15 seconds and touch it again and you will be shocked just how quickly it cools off.
This tells me that adding fins will do very little for cooling while driving, but possibly a bigger impact when the motor is sitting. But how much of an impact will it have while sitting with little airflow with fins should be tested.
What you'll find is that the addition of Statorade won't have much of an effect at all on the wh/km efficiency unless you're in situations where the motor core was getting up in the 100-150oC regions, and then it can start to be a player. For instance here is a trip with 3 big hills (~13% grade) and a fairly with stock H3540 Crysatlyte motor. Core gets to 180oC by the end of the trip, motor is running at 67.5% efficiency at the cursor location, and the winding resistance is at 0.24 ohms, and the journey burned through 98.6 wh/km (would be way better if the "regen enabled" was checked, but motor would also totally overheat)
And the exact same scenario with the only difference being ferrofluid in the core. Now we end the trip at 115oC, with motor running 71.4% efficiency, 0.20 ohms phase resistance, and using 93 wh/km for the run, compared to 98.6 wh/km previously.
auraslip said:Hhere is my contention with this idea that I haven't seen anyone address.
Is it abrasive? Will it rub the magnets or stator down? Because if anything magnetic gets in the FF, it's staying in there and that would be bad news.
Does it break down over time into something abrasive? What does this stuff look like after 10k hard miles?
markz said:Rust as well.
you could also epoxy pot the whole thing like he did above.. that thing is never going to rust. lol.macribs said:Best bet to avoid corrosion would be to spray paint the internals with inti corrosion, look at what Doctorbass have done. While your at it, give it a coat of flatt black to aid the cooling by radiation. Inject your hub with FF and seal and close the motor. You should be able to inject and forget and ride without any worry for a long time. And by the time your motor is "worn out" there are likely newer, more efficient and better motors on the market anyway![]()
Regarding rust/corrosion it seems vented side covers will be more likely to cause corrosion then ferro fluid inside hub. The oil coating of the motors internal should prevent corrosion? Keep in mind that moisture from the air can seep into the motor even if you do nothing to modify your motor. Water can travel via cables or get sucked into motor and can start to corrode even if you never have opened your motor.
auraslip said:There is nothing wrong with skepticism. Lets talk about my concerns rather than side tracking the discussion.
IIRC Justin has been recommending to his customers that have corrosion problem to drill the side covers to let the moisture out when it heats. Any moisture in a hot motor will be gone after a ride. You have a sealed motor, then moisture will be sucked in when it cools.
liveforphysics said:Can't speak for anything long term, but can tell you my last ride was harder than Ive ever pushed this motor and its not smelling foul afterwards like it used to with only half the amount of average power. It seems almost impossible 4.5cc of any material could do this, yet it works.
liveforphysics said:my last ride was harder than Ive ever pushed and not smelling foul afterwards.... It seems almost impossible 4.5cc of any material could do this
spinningmagnets said:Ester is the base material for aircraft hydraulic fluid...low smoke...low flammability...thin fluidity.
justin_le said:spinningmagnets said:Ester is the base material for aircraft hydraulic fluid...low smoke...low flammability...thin fluidity.
It also smells a bit funny, wheras the synthetic oil base has no odor at all. But otherwise in all performance and behavior tests I can't really tell the difference, though I should clarify most of my recent experiments were with the synthetic base since that was the bottle the I had had opened and received first.
Offroader said:I don't think abrasion is anything to worry about.
auraslip said:What does this stuff look like after 10k hard miles?
